Age question.....
Posted by: Charlezz on 13 May 2002
How old were you when you bought your first Naim???
As near as I am concerned, I bought myself a Nait3 2 years ago as I was 20 y.o.
6 months later, I had got a cd3.5/nac92/Hicap/Nap140 and today I have got CDX/Nac102/Supercap/Nap180.
Charles
Posted on: 13 May 2002 by garyi
wee
Posted on: 13 May 2002 by Phil Barry
Khoi wrote:
Je crois que le 92 est plus punchy, plus rythmique que le 72, non ?
My french is rusty: does this mean you believe the 92 to be punchier and more rythmic than a 72?
If I understand you correctly, you surely hear things differently than I do.
A 72 is better musically but far harsher on most source material than a 92. OTOH, comparing a 92/hi to a 72/hi is pretty easy - the 72/hi wins on all counts - PR&T, frequency extension, distortion, midrange accuracy, tonality, dynamics, musicality - whatever criterion you want to use, the 72 will win in 99 times out of 100.
Phil
Posted on: 13 May 2002 by mykel
Used Nait 1 in 1992. So I would have been 28.
michael
Khoi,
Well, I rate the 72/hi as a lot sweeter than a 92/hi. The 72/hi can be absolutely ravishing with Romantic orchestral stuff. The higher notes just sing on some recordings, and the music is so beautiful that the beauty can't be ignored, which is what I mean by sweetness. (I hope and trust the singing/beauty occurs because that's what the composer/conductor/performers want!)
You either have to listen for yourself, or take the plunge on faith. If you take a plunge with used equipment, your probably won't waste a lot of money, unless you trade with Parry or Lonorgan, both of whom appear to bargain very effectively! (This is not meant as a criticism of either Mick or Tony).
Regards.
Phil
Posted on: 13 May 2002 by Markus
Khoi,
If saving $ is important a used 72 would be an excellent choice. If your budget can stretch, a used 112 might be better in the long run.
But for value/money/music a 72 is hard to beat.
Markus
Posted on: 13 May 2002 by Martin Payne
I must have been about 20 when I bought my NAIT-1.
About six years later I had LP12/Ekos/Lingo, 52 & six-pack & Isobariks. I think the bug bit very hard!
Apart from replacing the Lingo with an Armageddon, things stayed pretty static for about six years, until I started working my way up the Naim CDP ladder (and then the speakers).
Now Naim start taunting me with 500's, 552's and God knows what else. Well at least the NAP500 isn't too far out of reach, with 6x 135s to sell off.
cheers, Martin
Posted on: 13 May 2002 by Barratt
25 Years Old
25 Years Ago
Posted on: 13 May 2002 by Manu
If $ (sorry Euro) is a problem, find a 32.5 updated to 72 (729 boards), can be found for very cheap.
IMHO it sounds better than a 92: more punch, more timing, sweeter highs.
Va faire un tour de l'autre coté du Chanel, il y a du choix d'occases chez les revendeurs Naim. wink
Emmanuel
Posted on: 13 May 2002 by Mike Sae
NACA 5 cable @ age 22
Nait 3 @ age 23
Posted on: 14 May 2002 by Charlezz
Khoi,
J'ai eu un Nait3, un Nac92/Hicap/Nap140, puis un Nac102/Hicap/Nap180 et enfin Nac102/Supercap/Nap180; donc je parle en connaissance de cause... le 102 n'a rien à voir avec le Nac92... Il est moins sec, plus musical, beaucoup plus fin... C'est comme comparer des enceintes Dynaudio et des enceintes Revel si tu connais... Le son des Revel est impressionnant, mais plus rustre, que celui des Dynaudio, qui sont plus ....féminines.
Je crois qu'il y a peu de différence entre un Nac72 et un Nac102... mis à part que le 102 a une télécommande, c'est une grande boîte (eh oui, ça le fait plus!!) et surtout qu'il peut accueillir une alimentation optionnelle (il est upgradable en somme).
Sans hésiter, achète un Nac102 d'occase si tu as les moyens; le nap140 est un très bon ampli et l'ajout d'une Hicap transcende le tout!!
Néanmois , si tu trouves un ensemble Nac92/Hicap/Nap140, vraiment pas cher , prends- le, tu pourras toujours changer plus tard; moi, c'est ce que j'avais fait: j'avais trouvé un ensemble Nac92/Hicap/Nap140 pour 11000F à l'époque; lorsque j'ai acheté l'ensemble Nac102/Nap180 d'occase, le magasin m'a repris le Nac92/Nap140 7000F , donc je n'ai pas perdu grand-chose!!!
CHarles
Posted on: 14 May 2002 by Steve Toy
Nac92/Hicap/Nap140
N'est-ce pas un système <<mullet?>>
A mon avis, le 92 est trop faible pour un 140, donc il faut un minimum d'un 72 ou d'un 102.
Le 140 revelera les faiblesses relatives du 92, même avec une Hi-cap.
Salutations,
Steve.
L'appetit vient en mangeant
[This message was edited by Steven Toy on TUESDAY 14 May 2002 at 21:48.]
Posted on: 14 May 2002 by Phil Barry
le 92 et trop faible pour un 140????
This sentence was probably written by someone who never heard a 92/140.
I'd take a 92/140 over a 72/140 ANY day of the week, unless I was sure that everything I listened to was a top class recording (which disqualifies most of what I listen to).
It's nice to have a 52, but the low end of the Naim line of electronics is quite good in its own right. I used to listen to equipment when i had a 62. I was constantly amazed at how much more I enjoyed my 62/140 than the mega-buck Classe, ARC, Krell, ML.
Regards. Phil
