QUIEX Pressings
Posted by: cafez27 on 26 June 2008
Does anyone know if you have to change the VTA for a 200gm QUIEX pressing as apposed to a 180gm due to the increased thickness??
Posted on: 26 June 2008 by BigH47
Might be worth posting in HiFi corner on this one.
Posted on: 27 June 2008 by count.d
If one raises the arm height for the 200gr, then it's different for the 180gr. Which one's best? One can't change it for every lp.
I've set mine to be parallel for the 200gr. At least it's slightly pointing down for the thinner lp's, which is better for me.
Posted on: 27 June 2008 by Martin M
I wouldn't bother. It's the tracking angle of the lathe that you are trying to reproduce (and which are all over the place in specification) so a couple of mm for the vinyl will make little general difference.
Posted on: 27 June 2008 by Fulcrum
Originally posted by Munch:
I have lots of 180G/ 200g albums.
I just put them on my LP12 and play them.
Surely the best answer!
Or, "How I Learned To Stop Worrying And Love The Vynil"
Fulcrum
Fulcrum
Posted on: 28 June 2008 by cafez27
Fulcrum
Wise words and exactly what I have done, and enjoying!!!
