speaker help
Posted by: ET on 05 July 2003
Hi,
I am currently using Castle Severn two way towers with my rega planet/32.5/hi/250 set up. I realize most people on the forum would suggest a cd player upgrade, but I have decided to keep it for the moment. I have been reading around and am trying to find some bargain speakers that would fit well in my odd room. Most likely I will be unable to locate the speakers far from a wall or very far from each other (less than 6' spacing) if they are on the same wall. Because of my budget I am looking at used speakers, and ideally something a little larger than a simple bookshelf so that I may get some bass (one of the main reasons I am getting rid of the Castles). I am considering Linn Sara's, Spendor SP2's and ? Since I will most likely be unable to demo a used speaker, what advice could the forum give? I mainly listen to rock/blues/jazz. I would be curious about placement issues and the characteristics of speakers you may recomend (forward/bright/etc). I currently have some Linn DMS Isobariks passing through my living room, and I can't afford them or handle their size, but I have really enjoyed the way they fill the whole room with sound and of course the bass (although I am not a complete bass nut). Small bookshelves with a subwoofer could be an option, but I think that would push me over budget. thanks for the help.
Tim E. - Seattle
Posted on: 05 July 2003 by Nuno Baptista
Try a Epos speakers .They work fine with Naim amps. You can get the Epos M 12
MY system : Naim Nait 5 amplifier,Naim cd 5 ,Epos M 15 speakers,Naca5,FC2
Posted on: 06 July 2003 by prowla
Don't rule out Kans.
Posted on: 06 July 2003 by coredump
James, those speaker look awesome! Were they thoroughly designed by you?
The reason I'm asking is that I have listened to some DIY-Kit speakers recently, but most of them sounded provided very 'round earth' sound qualities (excellent sound staging, depth, etc.), but could not stand up to a Kan in terms of 'playing a tune'.
Are you planning to release a sort of 'construction manual' for those speakers? :-)
Posted on: 06 July 2003 by ET
thanks for the replies.
would the epos really get that low in the bass?
James,
I am considering doing some DIY speaker work. I have pretty good woodworking skills and access to tools, and I can solder to a limited extent. other than that, I have no electrical skills to speak of. I am assuming I should start with a kit first and go from there. I have looked through your threads and you are obviously very knowledgable about the technical end of the speakers, where I am probably more interested in copying someone elses work to save some money and allow myself much more speaker than I could afford otherwise. Of the 2-3 projects you have posted on the forum, how much money do you think you have invested in the projects? I assume simply getting VIfa/scan speak parts and quality capacitors is a good chunk of the cost.
I would be curious as to your opinion on if a good diy project by an amateur could be made in the $300-500 price range
thanks
Tim
James,
I guess I would be interested in a good starting point. I can look at the schematic for a crossover, but I don't fully understand how everything goes together. Do the + and - runs actually touch each other at some point? With basic questions such as these running through my head, I have been considering buying a kit/plans and then based on this purchase having the option to question the company a lot if necessary. I have been looking at getting the kit plans from Shamrock audio for their MTM design (SE-2) as I would assume this would supply a fair amount of bass at a fairly low cost. The plans are cheap ($25) the parts are VIFA tweeters and drivers, and at the very least I could use the speakers in my shop, or if I am very happy, I could turn them into towers.
I guess at this point, with limited speaker experience (Castle/Linn/will be borrowing some JBL), I am not quite sure what it is that I prefer. From reading the forum, a fast tight bass sounds wonderful, although I would be very curious to put what is called a "warm" spendor sound against the Linn sound I have right now. I do need a fairly small footprint (tower or monitor) that will deliver a fair amount of bass and not be real location dependant design, or at least be a design that works placed against the wall. I am running NAIM electonics, so something that would play well with that, and I have a 250, so super efficent would not be critical. I have seen the PROAC clone on the web and some simple transmission lines that make me very curious, but I think I need something simple to start off that will let me "cut my teeth" a bit, but hopefully have some practical use. Or is that silly?, should I assume that as I build, I will then tear down and reuse or sell off for parts cost? and constantly keep going? I would be curious to hear your opinions on starting the hobby.
thank you for any help.
Tim
Posted on: 06 July 2003 by JohnMak
Hi James,
Those are great looking speakers you have posted.
Did you have a published design or set of plans you worked from?
Posted on: 07 July 2003 by ET
thank you James, I need to get my workshop completed and wired this summer, but I am looking forward to doing some woodworking soon. Hopefully it will keep me from spending my money on gear, and more on drivers, caps etc. I think I will do the simpler shamrock (SE-1) plan, since it will be cheaper and front ported, and then if that proves satisfying and up to my level of ignorance, then possibly pursue the proac clones or maybe hack together a t-line out of particle board just to see if something like that will work. I already have many more plans/ideas than I do time or money. thank you for the suggestions, and like everyone else, if you do start releasing some of your plans I will be very interested.
thank yo
