Any hardware changes done to AV2?
Posted by: M_N on 02 February 2007
I'm considering buying a second hand AV2 and have two examples to choose from. One with serial number 185xxx and the other 215xxx.
Have any hardware changes been done to the AV2 since it was introduced or are all identical?
If not, from wich ser.no. has what changes been introduced?
Thank you,
Mikael
Posted on: 02 February 2007 by AV@naim
Main changes to AV2 are firmware based.
To check fimrware, press and hold OSD button on remote for 5 seconds.
front panel will display:-
AVC0107/F658
for latest AV2 firmware
Posted on: 02 February 2007 by M_N
Thanks! I'll check what FW these two AV2's have.
And, hardware wise all AV2's are functionally identical?
Best regards,
Mikael
Posted on: 02 February 2007 by David Dever
It'd be silly not go for a later serial number, given two identical models at a similar price.
Later AV2 units are manufactured in the Series 5x/5i chassis with the silde-off lid, as opposed to the older Series 5 "clamshell" case.
