NAS - for all this work
Posted by: Ondra on 23 January 2010
My current configuration is: NAIM UNITY linked through TIME Capsule to iMAC 24 with snow leopard where majority of my digital music is stored as an Apple lossless (.m4a) managed by iTunes. I am using ExeConnect media manager. Uf.. :-)
I am thinking about switching to NAS solution (partially also to feed my PS3 and store Security cameras videos).
So I need NAS server (from NAIM user point of view):
to which I can transfer my Apple lossless (.m4a) library managed by iTunes
which can stream FLAC files in a way Unity can read them
which is is 100% manageable from iMac
I would like to have a possibility to access to NAS wirelessly (ideally through Time Machine router)
Is NetGear DUO (owned by many people discussing here) a good pick or Synology or whatever?
Thanks.
Posted on: 29 January 2010 by Steven Hopkins
I use a Netgear Ready Nas Duo, works great
Posted on: 29 January 2010 by Wazza69
I have a Neatgear Rady NAS Duo and it works perfectly and was very easy to setup. Pretty noisy though so best out of the listening room
Waz
Posted on: 29 January 2010 by rich46
sansung story 1.5 tera quiet ,handy on /off switch with discrete operating variable operating light
seems well made plus ripnas 1 tera ,again well made and no problems
samsung no problems at all £84
Posted on: 29 January 2010 by Music_Addict
I use Ve-Hotech VHS-4: 4Tb in Raid 5, Gigabit, Embedded servers (itune + squeeze) and store there all my computer data + pics + video+ Flac ...and you can also use it as a time capsule...what else do you need ? Ah yes, I forgot: I fully administrate it from the Mac... Winker
The special point of this server is very high throughput.Can read music + video + pics at the same time with no issue.
BR
MA
Posted on: 04 February 2010 by gaet
I have a qnap and it works perfect. It has twonky pre-installed and supports time machine !
