Soft focus in Elements
Posted by: DelR on 19 March 2010
Does anyone know how to replicate the effect of putting a soft focus filter under the enlargge lens, where the shadows bleed into the highlights in Elements?
Posted on: 19 March 2010 by garyi
I don't use elements guess gussian blur is your friend
Posted on: 20 March 2010 by winkyincanada
The best way to create a soft focus effect is to create a duplicate layer, apply guassian blur (experiment with settings), then adjust the transparency of the blurred layer to taste.
But I don't use Elements either.
