Uniti - HT bypass
Posted by: naimUnT on 10 April 2010
I was under the impression that the NaimUniti has a HT bypass feature. When I tried to connect a preamplifier, unfortunately, I could not find a way to hook it up so that the external preamplifier could be controlled independently. I have read the manual but cannot seem to find anything in it about HT bypass. Could anyone help me, even if it is to confirm that the Uniti does not have a HT bypass? Thanks in advance.
Posted on: 10 April 2010 by naimUnT
I must be suffering from memory lapse! I had already asked this question and a very helpful forum member (thanks Manu) answered my query - yes, it is possible to set any input on the Uniti to unity gain. Just go to "Input" and set "AV Fixed Volume" to "yes". Seems this is an 'undocuemnted feature!'
Posted on: 11 April 2010 by David Dever
Is listed in the Reference Manual, rather than the Quick Start guide.
Posted on: 11 April 2010 by Paul Hannan
sorry, maybe I'm being simple but why are you trying to connect to a remote pre-amplifier??
Posted on: 11 April 2010 by naimUnT
Paul Hannan: I was trying out my TVC preamplifier (transformer volume control). The unity gain feature allows me to bypass the NaimUniti volume. Its a useful AV feature.
