Just one final question about Foobar/DarkOne combination
Posted by: Hot Rats on 11 June 2010
I'm getting used to Foobar/DarkOne now and although I say it myself, I might even be gaining some proficiency!
One last question ... I can't find how to scroll down the biography window to read the text at the bottom!
can anyone advise please?
Posted on: 11 June 2010 by pcstockton
Right Click
Panel Properties (i think)
Enable Scrolling
Edit:
Wait a sec. upon further thought, I dont think you need to do anything. In the settings above you can request a "Scroll Bar". But either way the scroll wheel on your mouse should scroll when you hove over the text.
If you dont have a scroll wheel, select the "Scroll Bar" option in Panel Preferences (right click in Bio area)
Hope that solves it. If not I will look when I get home.
Patrick
Posted on: 11 June 2010 by Hot Rats
Couldn't see it under 'Panel Preferences' Patrick
Right click on the Bio Panel. Panel Pref.
Scrollbar - Change to Default.
Does your mouse wheel not scroll the text?
Posted on: 12 June 2010 by Hot Rats
Patrick comes to the rescue again! Thanks ... As always, I'm really grateful.
I added a second USB 1.5TB Samsung drive for backup and none of the links would work so I reinstalled everything. This morning I added a USB hub for the two USB drives ... The links didn't work again. Just finishing reinstalling and everything now works, including the scrollbar in Bio.
You're a star Patrick!
Posted on: 14 June 2010 by pcstockton
DJ,
I am very glad to help. Anytime.
regarding "none of the links would work", do you mean adding a new drive and Foobar not auto indexing?
You are using the "Media Library" right?
Preferences>Media Library (main tab)
Add all folders that contain music here.
It will auto-refresh on the fly.
-patrick
