What to do, what to do?
Posted by: JohnS on 05 October 2001
Gentlemen
I have somewhat of a dilemma.
I have the following kit: CDX/NAC82/SuperCap/NAP250/SBLs (with NAC5? cable) on a Mana four tier shelf, plumbed from a dedicated spur through a Wiremold power strip.
The Mana holds, from top down:
NAC82
CDX
SuperCap
NAP250
The stuff is plugged into the Wiremold in the order of (from nearest to mains cable) NAP250. SuperCap, NAPSC, CDX. The NAPSC is on a shelf on the Sound Org table, the top of which is used for the LP12 that doesn't work very well (the CD sounds better).
I really like the noises it makes and my toes tap a lot. My reservation is that sometimes it can sound a tad harsh. I have ordered a Sound Stage to put under the Mana table and I am about to order an XPS.
Am I going about this the right way? Are there arcane secrets I am not privy to? For example, should I plug the NAPSC into the non-dedicated spur?
Your advice is appreciated. Especially if it results in a zero-cost, music-enriching tip.
John
Posted on: 06 October 2001 by dave simpson
John,
Try the following plug order with the first item I list plugged into the outlet (outlet 1) nearest the wall (outlet nearest the strip's AC cord in other words).
Outlet 1: 250
Outlet 2: Supercap (82)
Outlet 3: CDX
Outlet 9: Napsc
I've found the napsc sounds best not nested in the plug hierarchy or on a separate circuit , but at the end of the strip. YMMV....
hope this helps,
dave
