Can anyone recommend a good 32" flatscreen,please?
Posted by: daryl on 18 May 2008
Hi,i am looking to buy a 32" flatscreen.
My main priority is to have very good picture quality with standard dvd and freeview.
Lcd or plasma?personally not sure,what i have noticed is that there is less reflections in bright rooms but the blacks are not as black with lcd.
I already own a 42" panasonic plasma and i am very happy with it.
The only 32" i have tried at home was a LG 32lc56 lcd and it was really bad,it was about 400 pounds,which i originally wanted to spend.
Will i have to spend alot more to get a good one,1080 would be nice for the future, but not essential at present.
So any recommendations would be appreciated,i am thinking Panasonic,but who knows.
Thanks for any replies, Daryl .
Posted on: 18 May 2008 by Guido Fawkes
I have a Panasonic TX-32LXD 700 and am perfectly happy with it. I believe it has been superseded by a Full HD model with FreeSat, which is probably even better. The Panny can upscale to 1080p at 24 fps, which I told is important and means it would work with BR and so on. It works well with DVDs of Danger Man, The Prisoner, The Saint and so on and The Trueman Show looks fine on it.
Posted on: 18 May 2008 by daryl
Thanks Rotf,any idea on price for the new model?
Daryl.
Amazon is selling the one I have for £649.99 - seems a bit steep to me. The reviewers on Amazon seem to agree with me - make sure any price includes a 5-year guarantee.
Ironically, the newer Panasonic TX-32LZD80 - 32" Widescreen 1080p Full HD LCD TV with Freeview is £635 from the same place. I think the RRP is £900+.
Panasonic TX-32LZD85 - 32" Widescreen Viera 1080P Full HD LCD TV with Freeview is £780.
ATB Rotf
Cheers Rotf! Daryl.
Posted on: 18 May 2008 by J.N.
Hi Daryl,
I'm very happy with my Panasonic Viera TX32LXD700 LCD.
Currently £849 at John Lewis with a five year guarantee.
John.
Thanks JN,that is two recommending the same tv.
It does not surprise me as i said i am happy with my panasonic plasma TH-42PX70B.
I will definetly try this one,cheers Daryl.
Posted on: 19 May 2008 by scottyhammer
daryl,
i have just purchased the new panny viera range lcd model tx-lzd850 which is excellent.
it worked out at around £1k with a 5yr warranty.
i know there is a 32" model too and john lewis stock them.
hope this helps. scotty
p.s. for more info see decision time thread
Posted on: 19 May 2008 by Frank Abela
The thing is daryl specifically asked for standard def DVD and freeview performance. I agree that the lzd85 is a very good performer for higher res but I'm not sure that all the extra work it needs to do to upscale standard pictures. If daryl really wants to stick to standard definition, he might be better off buying a standard definition screen or normal HD screen to reduce the work needing to be done and improve the picture quality from lower def sources.
Posted on: 19 May 2008 by JonR
May I recommend the TV I bought not so very long ago - the Sony 32D3000.
It has 1080i resolution (1366 x 768), so HD-ready rather than Full-HD but I think it is capable of wonderfully crisp and natural looking pictures - I think the inbuilt Freeview tuner is excellent too.
The model is a bit long in the tooth now so has doubtless been superseded, which means that if you manage to locate one you will probably end up with a bargain.
Posted on: 19 May 2008 by Jono 13
Another vote from me. The best LCD I have seen, please avoid the Sonys as they are not a patch on this one.
Jono
daryl may not want an all singing all dancing lcd but at least it would be future proof as he may oneday want to have hi def and br etc.
Posted on: 19 May 2008 by daryl
Hi all,well thanks again for the replies.
I went and had a look at some tv's and have to say ,Panasonic definetly gets my money again.
Although the Panasonic tx-32lxd700 is excellent,i have bought a tx-32lmd70a lcd because it also is very good and a bit cheaper and like i said it,s for standard dvd and freeview which it does the job very well, and i am really pleased with it especially for 499 pounds.
It is far superior to the LG i tried in every way.
See ya,s Daryl.
glad it al turned out ok for you daryl
enjoy Winker
Posted on: 21 May 2008 by Guido Fawkes
Excellent Darryl - good choice and you have another really good TV at a sensible price.
Enjoy it.
ATB Rotf
