Which "Olive to New" upgrade?
Posted by: Mike Hanson on 26 December 2003
I'm looking for a bit of insight (and a recounting of personal experience, if any exists), regarding a number of possible upgrade paths. My system still sounds better than I expect (i.e. what I hear in my mind when I imagine the music being replayed), which is quite a feat after almost three years without a big change in the configuration. (I did the Mana double-glass trick under my CDS2, I replaced the speaker cable connectors with Ecosse "Z" plugs, and I added a second dedicated spur and changed from 15-amp to 20-amp breakers.)
So I'm basically satisfied and feeling no pain. However, I'm always willing to "put up with" better performance
, as long as I don't feel too much corresponding pain in my pocketbook. Therefore, I won't spend silly amounts of money and I'm not in a big rush, and I'll be mulling over my options carefully. (This is in sharp contrast to my situation a few years back, when I wasn't satisfied with 3.5/Hi/102/NAPSC/Flat/140. I cast too many lines into the water, and within a month ended up with CDX/82/2*Hi/250, when a lesser upgrade would have probably satisfied me for a while.)
My current system is CDS2/XPS/52/Super/2*135, into Royd RR3 (coming soon). Here are my upgrade paths, as I see them:
I plan to audition XPS2 vs. XPS in my own system, as well as a new-250 vs. 2*135. When I do the XPS audition, I'll also try the new vs. old burndy. However, I'm not sure whether I'll have a chance to audition the 252 or the CDS3 options.
So what say you? Which of these makes the most sense, in light of my aforementioned criteria?
-=> Mike Hanson <=-
- Replace burndy between CDS2 and XPS with new one. This would be quite cheap, and I've read that it's better, but I'm not sure if it makes the most sense (keep reading).
- Replace 2*135 with new 250. This option would probably cost a bit more than the new burndy, but is still "cheap". A number of respected individuals have reported a worthwhile improvement. It seems somewhat counterintuitive, considering the lower output and single power supply for both channels. However, I remind myself that Naim amps with less power can often outperform much beefier offerings from other manufacturers, so they may be able to perform this same feat against their own earlier products.
- Replace olive XPS with new XPS2 (getting the new burndy in the deal). This is a more expensive, albeit potentially better, upgrade. It also adheres to the "Source First" philosophy. I've heard the XPS versus the XPS2 into a CDX, but not a CDS2. The key difference was less distortion: it was a cleaner, tighter presentation, with less hash. Not "jaw-dropping" by any means, but possibly more noticeable with the CDS2.
- Replace 52 with 252. This is probably more money than I'll willing to spend, but might be worth considering, nonetheless, if it's going to be significantly better than any of the other options above.
- Replace CDS2 head unit with a CDS3. Due to the cost, this one is quite unlikely. However, I'm willing to read any feedback that you can offer, and consider it appropriately.
-=> Mike Hanson <=-
