Nait2 and Headline?
Posted by: PflasterMan on 07 September 2003
Hi
for personal reasons I couldn't hear at my preferred levels (real, real loud ;-) any longer, so I consider to switch to the use of headphones.
Now my question: Is is possible to use the new Headline with a non-modified Nait2 - e.g. from Tape-In/Out? Has anyone experience with this subject?
The study of the owners manuals and the connection-guide didn't get me sure, if this is possible or if a pre-out is needed to drive the headline correctly.
Besides, do you recommend the Ergo 2 Headphone?
PM
- my sistem: Nait2, CD5, FC2, Intro2, Naca5 -
Posted on: 07 September 2003 by Potiriadis
Hi
I am running a headline of a NAIT 3 via the tape out and I am using Senheiser HD580's. These can be found regularly on ebay for £100.00 and are amazing cans, usually retailing for £200.00. They are like having SBL's strapped to your ears, utterly transparent and unforgiving, bu massivley musical. They are also capable of handling the absurd vlume loads of a Headline without distortion.
Help Bunnys everywhere!!!!!
No Seriously, everywhere!!!!!!!
Posted on: 07 September 2003 by Martin Payne
Originally posted by Andrew Dunn:
The NAIT2 tape-out will drive the Headline no problem. However, you also need a power supply (eg. a Flatcap) for this setup to work.
Since you have a FC2, this can power both the CD5 and the Headline at the same time.
I believe that a headline can also be powered by an NAPSC?
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
