Telling good vinyl from bad
Posted by: John C on 10 May 2001
I buy a lot of used vinyl these days and despite trying to be careful still end up with some dodgy sounding records. (I know I need to get a cleaning machine of some sort) At the moment I look for the general condition, obvious scratches, marks around the spindle hole, general sheen but anyone got a foolproof or simply better system?
John
Posted on: 10 May 2001 by Tony L
I'm afraid I find it is largely luck of the draw. I have vinyl which looks absolutely perfect but sounds crap, and some stuff that looks a little rough but plays fabulously well. One problem is that some vinyl sounded crap from new due to poor pressing quality, so even if it is in absolutely mint condition it will still sound bad. The vast majority of second hand vinyl I have bought plays great.
I look for obvious surface defects in the same way as you describe, though I am possibly prepared to buy vinyl in a dirtier condition than most as I have a very good record cleaner (VPI 17F). Even well kept vinyl accumulates dirt over the years, especially if stored in paper inner sleeves - cleaning makes an enormous sonic difference in some cases.
The quality of turntable and cartridge make a big difference, with some deck / cartridge combinations tracking very much quieter than others. In the rare event that a deck / cartridge dem is available take some old vinyl - when I bought my P9 I arrived at Frank's shop carrying a stack of original 60s jazz.
Tony.
Posted on: 10 May 2001 by Former member
I believe that there were certain times over the last 40 years or so where the quality of the plastic / vinyl changed due to raw material supply problems. Recycled materials were used to keep the costs down during energy crisis times etc, and in some cased any old crap, shellac, bits of tyres etc were used.
I think this varies by company, lable and years.
I may well try a web search later to see if anyone has any info - the dates etc to watch for might be useful. Anyone any clues?
Would such problems be immediately evident to an experienced 2nd listener vinyl-hound?
Jonathan
Use of the word "vinyl" in a search seems to produce a few sites that my service provider/employer might not want me to look at.
A quick search provided nothing material - apart from the following slight tangent:-
http://tinpan.fortunecity.com/bentley/565/
Jonathan
The following are just my experience:
50s and 60s pressings: Virtually all are really good. From a jazz buyers perspective Verve, Impulse, Blue Note and Prestige are all usually stunning.
70s pressings: On the whole very good, certain labels were excellent: UA, Decca, EMI, Island, Virgin and Harvest spring to mind. RCA were also good, but produced some of the thinnest vinyl known to man. I have seen carrier bags thicker than my copy of Hunky Dory by Bowie, they sound ok though.
80s pressings: Often pretty dire. Factory, 4AD and Rough Trade were good, as were many of the other independents. A lot of the majors produced horrible quality vinyl, I remember taking Swordfish Trombones by Tom Waits back about 5 times in the vain attempt to get a quiet copy, this was typical from Island at the time. The mid priced reissues from the likes of Electra and RCA were pretty naff sounding compared to the originals - you want your Bowie, Lou Reed and Iggy Pop albums to have orange RCA labels, not green or black.
90s: Things started to get better again. 180gram cuts seem to be almost the norm these days, and whilst audiophile cuts are really expensive, the likes of Alto Analogue and Classic Records have produced vinyl as good as many prime 50s and 60s cuts.
Tony.
Posted on: 10 May 2001 by John C
Thanks.
Those 50s and 60s Jazz recordings are increasingly expensive these days. The Ebay and on-line auction factor has inflated prices hugely. As for Blue Note's almost impossible to get anything decent these days even 70s 80s reissues £12-15 minimum. With BN reissues Japanese versions seem better than the French or American . The OJCs are great value though and as Tony says, better still the 70s Prestige, Riverside or Contemporary records.
Johna
Posted on: 14 May 2001 by Eric Barry
On jazz, I've found Prestige dodgy, and Riverside too. Some great, others poor, in terms of pressing quality. I think the best sounding jazz lps, and this is true all the way through the 70s, was Contemporary. The music is usually a bit genteel and California, but the sound is fabulous.
For rock, there is just tremendous variability. In the indie field, SST, Sub Pop, and Touch and Go are and have been exemplary in general. Much of the American indie music of the last two decades was mastered by John Golden at K-disc and now Golden. He always did a great job.
In terms of surface noise, I find it is myriad light hairline scratches, rather than obvious scuffs, which bother me. They are not even visible in a lot of light (esp. fluorescent). So it's always the luck of the draw. But older records seem to hold up better.
--Eric
Posted on: 16 May 2001 by David Stewart
For what it's worth, I used to know someone in quality management at EMI in Hayes. That was in the early eighties. He admitted LP quality could be very variable then and was dependent on many factors. Amongst these were the vinyl quality, cleanliness of the pressing equipment, pressing temperature, handling issues, operator skill and very importantly how many pressings they tried to squeeze out of a set of press-tools before refurbishing them. Tooling costs were v.heavy and hence the admitted tendency was to try and squeeze out many more copies than was ideal.
Overall my impression was that, by default, cost control normally had a much higher priority than quality control. Hence all the poor pressings from that era. Its good to see that the newer vinyl makers like Simply Vinyl are taking a much more pro-active approach to QA.
David Stewart
Posted on: 17 May 2001 by P
I gave up with vinyl about 10 years ago - the quality just wasn't there anymore. I do still have a deep rooted love of the stuff however and have been meaning to buy a serious new deck for some time.
That time is now (cash register kerchinking noise just heard in Reading!)
Before I finally take the plunge though can I ask- just how good are the Simply Vinyl reissues?
I just checked their site and found they have a whole load of albums that I already own but would like to hear again in comparison.
If I were to dip my toe in here I might just end up diving back in to the vinyl market big style so I would really appreciate any thoughts on how these reissues generally bear up against the originals.
Peter
Posted on: 18 May 2001 by von zipper
Unfortunately,quality once again seems variable-I found Dylans 'Blonde on Blonde' had excellent sound and detail whereas other such as 'The Notorious Byrd Bros.' sounded a little flat...it all depends on the mastering i guess...but at up to £20 per disc I can't help but feel we're being ripped off a little...you can probably find a good original 2nd or 3rd pressing of most titles for cheaper....
Posted on: 18 May 2001 by Tony L
I only have three in my possession, and my feeling is that they are really excellent pressings (e.g. very quiet and flat), but the quality of mastering is nothing special at all. They make absolutely no audio quality related claims in their literature, there is no mention that I am aware of relating to the use of the original masters, or even of an analogue source.
Don't let this put you off buying getting an analogue source, there is a lot of great music currently being released on vinyl. There is also a thriving reissue industry with labels such as Alto Analogue, Classic Records, and DCC all producing stunningly quality products, albeit at a price premium over standard pressings. I buy a combination of mainly new and second hand vinyl, though I will also splash out on certain audiophile pressings of classic jazz albums.
Check out www.vivante.co.uk for the audiophile stuff, www.diversevinyl.co.uk for a mix of regular and audiophile pressings, and www.rocketgirl.co.uk for an excellent selection of honestly priced indie vinyl.
Tony.
Posted on: 19 May 2001 by P
Thanks for the replies re Simply Vinyl and the other links guys
I have been itching to hear some of my old albums in comparison to the remastered CD versions that I now own so I have formulated a plan of action which initially involves reviving my 20 year old Thorens TD318 as a first step and possibly having my old albums cleaned up by someone.
I have really missed buying vinyl in some ways. I also miss having to get up out of my chair every 20 minutes or so to change sides
razz
The ball is rolling
Pete
Posted on: 21 May 2001 by von zipper
I'm always attracted to those nice '180 gram'
stickers on re-pressings and now we're starting to get 220 gram vinyl as well,but does it actually make any difference to the sound?
Is there any advantage in having thicker vinyl?{apart from being slighty more resistant too breaking after having been sat on during a 3.am drunken 'i luv vinyl session'....but thats a different story....)
If it is the case that thicker is better{as many girls arue) why aren't we seeing discs 2 or 3 inches thick?
anyone?anyone? wink wink smile smile smile
dislecksier rools.....
Posted on: 21 May 2001 by Tony L
I remain to be convinced that the thickness / weight has any bearing on sound quality at all. Take Blue Note, I think the thin 1985 French vinyl possibly sounds better than the current 180g stuff, it certainly sounds no worse to my ears (though I do not have any duplicates, just 12-20 albums of each era). I likewise site original UA Can albums, or original 60s US Verve label pressings as being amongst the best sounding vinyl I own, again probably weighing in at about 120g.
What matters is the quality of the cut, the quality of the masters, and the care taken in pressing. The reason to lash out 20 quid on say an Alto Analogue or Classic Records pressing has little to do with the weight of the vinyl, just the care they take in all areas of manufacture. I would site the likes of '234' by Shelly Manne and 'Out of the blue' by Gil Evans on Alto, or 'Ah Um' by Mingus on Classic Records as being amongst the finest vinyl I have ever heard. 20 quid well spent.
Tony.
Posted on: 11 June 2001 by Former member
Tony Lonorgan
I emailed Simply Vinyl to ask if they always used the original masters for their re-issues.
They didn't reply.
Draw what conclusions you will.
All the best,
oops
Posted on: 12 June 2001 by Peter Stockwell
A mate has a big pile of Simply Vinyl recordings, mostly reissues of 70's stuff. He singles out Unhalfbricking and a Nick Drake recording for being particularly good. He bought a couple then ordered a lot more, because he was so pleased.
I've only listened to Unhalfbricking, which sounded OK, but his vinyl front end was still in 'running in' mode.
Peter
Posted on: 21 June 2001 by Haroon
I think the reason for thicker vinyl maybe because they can cut it better than the thin stuff. I do have some ordinary stuff that does sound better than simply vinyl - what I have heard is that they use what they get - which quite often is not the orginal analogue masters like Classic do.
I also ordered kindo of blue analogue re-issue (£40) turned out my us import copy for £10 was just as good. I had to return it, and was told other people had done so too - bad pressings. Anyone out there with a decent copy?
Posted on: 03 September 2001 by Former member
I have several Simply Vinyl 180gm pressings that are excellent. Elton John's "Goodbye Yellow Brick Road" Double Album though sounds very noisy, scratchy and lacking in dynamics. I contacted Simply Vinyl about it but, surprise, surprise got no reply! Seems typical for about half the companies on the internet. Perhaps they know it's a bad one or they just don't care for criticism.
Stephan
Posted on: 04 September 2001 by John C
I'd be very surprised if Simply Vinyl replied to all the emails they get on their production process as presumably there are a large number of vinyl loonies pestering the hell out of these companies. This is a recent thread on the vinyl lunatic asylum with a reply from SV
http://www.AudioAsylum.com/audio/vinyl/messages/75203.html
Johne
Posted on: 05 September 2001 by Former member
Hi John C
I understand their problems and don't wish to bash a company we don't want to see go.
Could be simply solved by noting on the cover what the source was they used?
Stephan
Posted on: 05 September 2001 by Hermann
hi all,
got the record "Grace by Jeff Buckley" of simply vinly since yesterday. This record is really good!! In both ways the music itself and the qualitiy of recording and pressing. smile
On the other hand I own 4 copies of "Blind Faith".
A UK a ATCO (USA) a MFSL and (since yesterday) a Simply Vinyl pressing.
The best is the MFSL followed by the UK then ATCO and the worst is the SV pressing.
The difference is that big that I can't believe SV use original master tapes.
Hermann
Posted on: 07 September 2001 by Mike in CO
I remember reading an article several years back from my hi-fi dealer that helped "decode" the numbers stamped near the lead-out groove, near the label. I remember the article noted the different numeric schemes used by the major LP manufacturers, (identifying mother/stamper numbers, reissues, etc). It also noted what mastering houses were known to be better than others, and how to identify based on symbols or initials recorded. I've looked around the Web for this information, but haven't found any. Has anyone else seen this? (Or kept a copy of the article, by chance?!)
Posted on: 07 September 2001 by Former member
Have you heard Mark Radcliffe and Mark Rileys section on Radio One about buying used vinyl?
It is called Classic cuts and can be heard from Monday to Friday at approx 2.45pm. I have found this section offers excellent advice on purchasing used records.
Some useful terms when browsing through Record collector magazine are as follows...
M = Mint, N.M = Nearly Mint, T.O.S = Tear on Sleeve, and S.H.I.T = Not very good.
I recently purchased a Paul McCartney album second hand. Unfortunately he had written his name in gold pen on the cover. The advice I was given by Classic cuts was to remove it with Turps and a rag. This worked a treat! The sleeve looks better and I've probably doubled the value of the record.
Posted on: 07 September 2001 by SaturnSF
If Paul McCartney wrote his name with gold pen on the record, I doubt you doubled its value by wiping it off!!
