Packaging
Posted by: Dungassin on 01 June 2010
Bought a new 2GB Verbatim USB stick because I'd lost my other one. (used principally for taking photos to be printed)
As usual if came in that stupid type of packaging which you have to destroy in order to get at the contents. Finished up taking a sharp knife to the plastic to get it out.
Why oh why do they do this? Means that if you buy an article and then find it doesn't do what you want until you've opened it, then you have to go cap in hand to the shop to get them to take it back.
