Naked Snaxos
Posted by: Naheed on 18 July 2002
I've seen a few pictures where people ten to leave the snaxo cover off, and recall someone mentioning a sonic benefit, the same i comment was also made regarding the napsc.
Anyone heard of this - doing this ?
naheed
active is the only way...
Posted on: 18 July 2002 by Steve Catterall
Yes - I've heard that there is a sonic benefit from leaving the cover off, and while I had an active set-up I had the cover off most of the time, although I can't say I noticed that much difference when I put it back on.
The advantage of leaving the cover off for me was the ease of making adjustments to the settings. Once I had those sorted out, I put the cover back on ... and couldn't really hear a detrimental effect on the sound, so I left it on.
Posted on: 19 July 2002 by Naheed
Cheers Steve, i'll leave it clothed then...
naheed
Posted on: 20 July 2002 by bob atherton
Hi Naheed,
I leave the cover off my SNAXO & have noticed a big difference in doing this. I didn't know that it was a 'tweak'. I spent a couple of days sorting out the settings for my IBL's, was happy with the sound & put the case back on. The sound became very congested & shut in by comparison, much less air around the instruments & vocals & also a subjective fall off of the higher frequencies, cymbals had less shimmer.
I wish to my ears it would sound the same with the case on as it looks a bit of a mess & collects dust. Please forgive for asking but you do put the rubber feet back on when listening 'naked' ?
Bob
Posted on: 20 July 2002 by Naheed
Hi Bob
I have'nt removed the cover yet, but i'd assume the rubber feet should stay on
naheed
