mp3 players
Posted by: jason.g on 07 October 2005
I,ve finally took the plunge and placed a crazy bid on ebay and managed to win myself a 512mb mp3 player for £29. its a pocket sized "TRUE 512mb with fm radio". I have no idea how mp3 players work, the sound quality or human/machine interface. Is it easy enough to download songs onto it or do I need specialist software? My pc is running XP and I have NERO 6 Enterprise edition (never used it?) HELP!
Posted on: 07 October 2005 by garyi
Jason these no name products usually work on the premise of a harddrive. That is to say you goto 'my computer' and it will appear as a drive. Drag MP3s onto it to have them go over.
in future buy a ipod shuffle and get itunes, you will find the whole experience a lot more fulfilling.
Posted on: 08 October 2005 by jason.g
how do i convert my cd's to mp3 format then?
Posted on: 08 October 2005 by Nuno Baptista
With software. You need windows media player or another like Express rip! You need to rip the cd audio!
looking at my programmes, i think nero express is part of nero 6. if i have it, can anyone point me in a good starting direction.
Posted on: 09 October 2005 by Chumpy
Posted on: 09 October 2005 by jason.g
If I already have wmp 9 and Nero 6, do I need to download extra programmes? My computer is slow enough as it is without clogging it up with duplicated programmes.Do mp3 players normally come with relevant software?
Posted on: 09 October 2005 by long-time-dead
Ever wondered if you should have bit the bullet and bought an iPod ?
FFS - we spend countless thousands on audio equipment but debate endlessly on a portable player.
They ARE crap - buy the easiest one to use and the one with the best PC interface to use.
Choose colour and disk space - simple.
Posted on: 09 October 2005 by Bob McC
won't it come with proprietary software?
Bob
Bob
Posted on: 10 October 2005 by Nick_S
The best software combination for producing MP3 files under MS-Windows is Exact Audio Copy with LAME, both of which are free software. EAC uses multiple passes to produces errorless audio files in WAV format and then calls LAME to compress them as MP3 files.
http://www.exactaudiocopy.de
http://lame.sourceforge.net
Nick
Nick
Posted on: 10 October 2005 by Nuno Baptista
quote:Originally posted by long-time-dead:
They ARE crap
The iPod has a beautiful sound!
Posted on: 10 October 2005 by Diode100
Atta boy, Nuno, give it to them straight.
How easy is the Exact Audio Copy & LAME to set up, ans does if have the some sort of management system as per iTunes ?
I have been told that Winamp also have a high end conversion programme for MP3 files, does anyone have any experience with it ?
Posted on: 10 October 2005 by Guido Fawkes
Glad you like your iPod. Did you buy the manual? Next step is upgrade to an Apple computer
Rotf
quote:Originally posted by ROTF:
Glad you like your iPod. Did you buy the manual? Next step is upgrade to an Apple computer![]()
Rotf
The rough guide to the iPod & iTunes is excellent, its based on the Apple products, but has a lot of general information, applicable to MP3 players in general.
"How easy is the Exact Audio Copy & LAME to set up, and does if have the some sort of management system as per iTunes ?"
From memory, download each and unpack the zip files into their respective directories. The questions asked by EAC during the installation were straightfoward as it worked out my drive and correctly callibrated the offset. The file management software will depend on your mp3 player, but ID3 tags can be generated.
The advantage of using EAC is that you can make error-free copies to CD-Rs as well.
For file management, I just use the file directory structure: genre\artist\album, which I find makes it easy to maintain and add new albums. With iRiver players the access time is faster using file-trees rather than the music database.
Nick
Nick
Posted on: 10 October 2005 by jason.g
Idon't doubt the quality of these players but i,m only dipping my toe in the water to see if I like the idea of them. I already have a sony portable minidisc , portable cd player AND portable dvd player. Unfortunately none play mp3 and as technology moves on, I find myself in the possesion of many cd's with multiple mp3 files/albums, of which I only have to copy onto individual cd,s to enable me to listen to them on the move. Portability is the way ahead and i,m sure its impossible to hear music in full clarity whilst riding my bike to work on a windy day, or going for a jog. If it turns out I like the concept then bring on the big guns.
Posted on: 30 October 2005 by jason.g
Got my mp-3 player/fm radio shipped from hong kong and yep, it's cheap, fiddly and the earphones have gone straight in the bin for what they're worth but it,s neat and does what I ask. I downloaded a programme called express rip (http://www.nch.com.au) and it,s so easy to copy cd files and rip them to mp-3. it downloaded in about 80 seconds.
Posted on: 30 October 2005 by Steve G
A problem with most of these players (including the iPod) is that the standard earphones are crap. When used with decent headphones the sound quality can be pretty good if a high sample rate is used.
