My DAB radio doesn't...
Posted by: Robbert on 22 August 2009
...work on my uniti. What do i wrong??
Can i connect the normal cable AND an antenna for DAB?
Here in Holland they say you don't need an antenna for DAB radio. There should be one inside the case. Is it also in the uniti? Or must there be connect an antenna?
Posted on: 22 August 2009 by garyi
I have never got dab or normal radio to work in my living room, even with a normal arial connected.
That being said the iradio is superb have you tried it?
Posted on: 23 August 2009 by Robbert
iRadio does work very well. It plays whole day. But DAB is also a nice thing to try and they have good programms on it here in Holland which i wnat to listen.
Posted on: 23 August 2009 by Exiled Highlander
Robbert
What is your dealer saying about it? I'm sure that would have been the first call you made after your discovery.
Jim
Posted on: 25 August 2009 by Robbert
I checked but I'm in a smallest part of the aria where the power of the signal is very very low. So that's why i don't get it Frown
Posted on: 28 August 2009 by Klout10
Is this the reason it's for sale now??
Michel
Posted on: 01 September 2009 by Robbert
Michel
No !
Posted on: 01 September 2009 by Exiled Highlander
Robbert
Going to share why then?
Jim
Originally posted by Exiled Highlander:
Robbert
Jim
Too hungry speakers.
Posted on: 01 September 2009 by Klout10
Big Grin
Michel
Posted on: 03 September 2009 by Robbert
Big Grin
Michel
Why Big Grin
Posted on: 03 September 2009 by Klout10
Robbert,
Big Grin because it sounds familiar: that's why I changed my Nait 5i for a SuperNait (and my CD5x for a HDX).
Now I'm perfectly happy!
Michel
