Is Naim running short of transistors ?
Posted by: hifidaddy on 13 March 2001
When I visited www.zetex.com, supplier of transistors, I realised that some types used in the Naim preamps, like ZTX384, are marked obsolete from end of March 2001 on the site http://www.zetex.com/s46.shtm.
Did I mix some things, if not, then I am asking, what is Naim going to do ?
regards,
Hartmut from Munich
Posted on: 13 March 2001 by Paul Stephenson
"what is Naim going to do" buy a lot!!
Posted on: 13 March 2001 by Greg Beatty
Paul -
The language may not be quite right, but if the transistors are marked "Obsolete" rather than just "Discontinuted", then perhaps the manufacturer has what they feel is a better version of the component. If so, would Naim try the new one and then decide whether to use the new one or stockpile the old one?
Just curious...
- GregB
Posted on: 13 March 2001 by bam
Hey Paul,
I've got a few in my cupboard if you run short. Just let me know mate.
BAM
"Naim try the new one and then decide whether to use the new one or stockpile the old one?"
This unfortunatley is almost a monthly occurence. We spend a large amount of our R&D time looking for replacement components. We have a most endangered list!
We would always try to find a replacement but if not or until we can find an alternative or a re-design solution, we buy, in some cases five years or more stock! (doen't look very good on the balance sheet)
Posted on: 14 March 2001 by Peter Stockwell
Paul
balance sheet)
No worries for the 5 series then, coz' I'm thinking of a NAIT or 112/150.
confused
Peter
Posted on: 14 March 2001 by Paul Stephenson
No Problem, go for it!!
