i tunes .. the best way to proceed ?
Posted by: kev 1966 on 31 October 2008
Hello,
looking for some guidance please,
At the present moment I have itunes loaded on my laptop. With tunes stored in the standard format roughly 4000 songs
My queston,
I would like to move this forward.
This is what I would like to achieve I just don't know how to get there
Music thought main sysyems as my profile
and the oppertunity to use my itouch ? as a means in the bedroom
I was looking at the i mini / Beresford ?
Active speakers in the bedroom Audioengine ?
How and do i need to start a new itunes library in a better format ie lossless
Any help pointing me in the right direction would be appreciated
Kevin
My queston,
Kevin
Posted on: 31 October 2008 by james n
Kevin - i dont know what you have as a home network but this is what you could do...
Mac mini with the main system - with a DAC of your choice (plenty of discussions on good and bad on here ...)
You can control iTunes with a touch. If you want speakers elsewhere then an pair like the audio engine with an Airport express will make a low cost multiroom setup. If you want to go full multiroom then something like the Sonos system is designed for this.
As for your music - store in apple lossless or if you have the room, uncompressed.
Hope that helps
James
Hope that helps
James
Posted on: 31 October 2008 by kev 1966
Thanks for the input James, I'm basicly starting from scratch
I like the ideas of the Mac mini ( was inspired by one of your pictures )
At the moment itunes is on my Laptop, Will I need to reimput all the collection to get a better sound quality ?
Sorry about the basic question
Hi Kevin - is this music downloaded from iTunes or ripped from CD ?
James
James
95% Ripped from Cds
Kevin
Kevin
Posted on: 31 October 2008 by Former member
Kev,
Have a look on this thread.
It might help.
Munch
It might help.
Munch
What settings did you rip your CD at ? - Lossless/ 320k / 192k ??
James
James
James,
AAC 128K which seems to be the standard format, do't think I changed anything
but it was a long time ago
Kevin
Kevin
Looks like to time to re-rip then. I'd get your DAC and get set up and they play with rip settings. Storage is cheap these days so rip in Apple lossess or AIFF and you can't go wrong.
James
James
Thanks James
Will order my speakers for upstairs, think the mini might be my christmas present to myself
selfish but what the hell !
Thanks again
Kevin
Thanks again
Kevin
No worries - good luck
James
James
Just had a thought is there any reason why I couldn't delete itunes on my laptop re rip Cds in higher quality format?
Then put the laptop through a Dac till the mini arrived ?
Could itunes then be backed up and transfered to the mini ?
Kevin
Kevin
Posted on: 31 October 2008 by garyi
Of course. Start your library now. You will find all them tracks neatly organised by artist folder: Album folder in the itunes folder.
On mac, home folder>music>itunes
On PC, my documents>itunes (I think)
Once your mac arrives transfer the files over via ethernet , removable harddrive etc.
If you have a USB harddrive I recommend setting itunes to save music on this drive, saves a bit of leg work later.
Posted on: 31 October 2008 by Keith L
Kevin,
I assume when you say delete itunes, you mean delete the music files you have already ripped. Yes, start from scratch. Delete what you have previously ripped. Rip in Apple Lossless or Aiff using your laptop. You will be able to transfer your ripped directory to your new computer/MacMini.
ATB Keith
ATB Keith
Gary / Keith
If I delete all the itunes files, then re rip
should I be setting the preferance Apple Lossless Encoder ?
Kevin
Kevin
If your intention is to use itunes as a means of playback then yes.
As its lossless you can always convert to wav or AIFF at a later date (the original file)
Thanks Gary,
Think thats a job for tomorrow some how, appreciate the advice.
Kevin
Kevin
Posted on: 01 November 2008 by kev 1966
Old setting on itunes deleted, started ripping
this is going to take a while !!!
Posted on: 01 November 2008 by garyi
MAke sure its lossless or AIFF, either of these settings is as it was off the disk, you can always take away you can never add!
Gary,
Ripping in lossless, is there a way to compress the files for use on the i pod?
Kevin
Gary,
Kevin
No not really.
The easiest way is to import the tracks as lossless then convert some of them for your ipod, or just accept the ipod won't hold so many tunes.
Posted on: 03 November 2008 by kev 1966
James / Gary
Advice please..
Have ripped 100 cds to my pc, and have now decided to go and but a external hard disc ( Iomega Minimax the one that matches the footprint of the imac) I can transfer the library to the Harddisc.
Will there be a problem with formats ?
Kevin
Advice please..
Kevin
Posted on: 03 November 2008 by garyi
Assuming there you went with lossless then that is not an issue. What might be is that you are currently on a pc.
The new drive really wants to be in apples extended format.
The easiest way I should imagine is get the two computers on the same network. And put the itunes folder from your pc into the public folder. aznd allow it to be shared (I think it is by default)
Back on the mac, goto syetm prefs and sharing then advanced and turn on SMB sharing.
After a while your PC should appear on the mac in any finder window on the left select it and the public folder will appear, drag the music from it onto your shiney new drive.
This is a bit of a work around as you really don't want to format your new drive as FAT (which is readable by both PC and Mac) as its slower
Posted on: 04 November 2008 by kev 1966
Well Totally confused, got my nice new MiniMax hard drive home..
Plugged it in, thinking they said they had formatted it at the shop for me .. Great I thought
Well I've managed to partioned the drive as per the instructions
But it's now asking to be formated . But the only options its giving me is NTFS
Any help please
Any help please
Posted on: 04 November 2008 by Former member
Kev,
Did you know you can clone any Ex hard drive to become your Mac?
Munch
Munch
Munch,
I'm trying to get the music of my pc, mac won't happen for another month !!
