House wiring for Naim?
Posted by: avhed on 07 July 2006
Does anyone know if there is a certain type or brand of in wall wiring that will improve the performance of Naim equipment?
Posted on: 07 July 2006 by manicatel
There are quite a few threads here about having separate wiring spurs installed for best effect. Most mention wire diameter, & plug-socket & switches reccommendations.
Try doing a search for "spur", or similar.
matt.
Posted on: 08 July 2006 by Engelbert
Yes, house wiring is important - especially when you get into the reference series (big box) kit.
Dedicated mains/spur would probably be the most cost-effective upgrade I have ever undertaken. You need expert advice on this issue. (My local electrician couldn't understand what I was on about. Suspect he thought I was nuts.)
Enjoy your music,
Rob
Posted on: 09 July 2006 by avhed
I am wondering if anyone has tried the JPS In-Wall
Wiring or similiar to power Naim equipment?
