Snow Leopard anyone?
Posted by: BigH47 on 25 August 2009
Any Appleites have a view on this upcoming release?
Posted on: 25 August 2009 by Derek Wright
The Apple shop is doing a free shipping offer for a few days - remember just because you have a copy it does not require you to install it until several point releases have passed and be proved to be OK.
Posted on: 25 August 2009 by Lontano
I will be upgrading. Family pack - 5 licences for £39 seems a bit of a bargain. Will wait and see how successful the release is first before I take the plunge.
It really seems to be a release for quicker booting and closing, quicker attachment to wifi networks and less hard disc space.
Posted on: 25 August 2009 by Absolute
I will be upgrading most certainly. Very interested to see whether the improvements make a noticeable difference. 'Grand Central Dispatch' could well prove to be fantastic. All the cores in the world aren't going to make a difference unless the software is written to utilise them all effectively. Same with 64-bit system apps.
For £25 its almost silly not to. My system could do with an overhaul as well, so convenient timing.
Posted on: 25 August 2009 by ferenc
Really snappy on my Macbook, no downside yet, works smoothly and perfectly well, without any compatibility problem (the Gold Master verison I mean)
Posted on: 25 August 2009 by scottyhammer
ordered mine online today should get it monday
Posted on: 26 August 2009 by GML
Same here Dave.
Posted on: 26 August 2009 by OscillateWildly
Isn't it more of a tidy up than recent releases? Not so much wait for the first update?
OW
OW
Posted on: 26 August 2009 by rodwsmith
You can always drown your sorrows in 'luxury' vodka if it doesn't work.
Posted on: 26 August 2009 by tonym
As I bought a Mac Mini in June, I get the Snow Leopard for £7! A no-brainer, as they say.
There's always the nagging doubt about being a "First Adopter" but I'll probably give it a couple of weeks before installing & meanwhile look on the Apple Forums for any glitches.
Posted on: 26 August 2009 by Absolute
The Register has a quick bit on the beta release if anyone is interested. They speculate nothing much changed between than and the final version.
Posted on: 27 August 2009 by Steve Bull
As I am on 10.4.Luddite my only option seems to be to buy a set of Snow Leopard, iworks and ilife for a less than appealing £129. 10.4, here I stay.
Posted on: 28 August 2009 by Derek Wright
Not only is today Snow Leopard day there is also an update for Aperture.
All this and within a week of the BBQ in Salisbury.
Posted on: 28 August 2009 by Exiled Highlander
I'll don a suit of armour and brave the heaving masses at Oxford Circus and pick up a copy at the Apple Store on Regent St at lunchtime and all being well will have it installed by 6pm or so tonight....
Jim
Jim
OK...I fibbed....installed and running by 12 noon.
iTunes music now sounds 3.8x better.
OK, I made that last bit up.
Jim
Jim
Posted on: 28 August 2009 by Petef
Patiently waiting for my copy to be delivered so I can install it
For info its worth checking the following websites prior to installation to check all your software is compatible
http://support.apple.com/kb/HT3258
http://snowleopard.wikidot.com/
Pete
Pete
Posted on: 28 August 2009 by Absolute
There is also a list here of apps that you will have issues with on Snow.
http://www.theregister.co.uk/2...d_incompatibilities/
Posted on: 28 August 2009 by scottyhammer
Jim,
Let us know what you think please as you seem to be ahead of the game.
Regards, Scotty
Regards, Scotty
If anyone is using SONOS when you install Snow Leopard the controller software doesnt work initially but speaking to a guy on the SONOS forum you just download and re-install the version 3 software to fix the problem
Pete
Pete
Scotty
Seems fine and stable so far. Things may generally be a bit snappier....I haven't played with any the new features yet but to be honest most of the improvements are under the hood. Not a glitch on installation and it took about an hour on this 3 year old MacBook Pro.
Jim
Jim
OK, I fibbed again. I have a problem with the Desktop/ScreenSaver preference setting. Every time I try to open it it crashes out of Preferences.
Time to do some research to see if anyone else has come across this.
Jim
Jim
Posted on: 28 August 2009 by ianmacd
Loaded Snow Leopard this morning on a second h/drive inside my MacPro 2.8 Dual Quad Core (original Leopard 10.5 still loaded on first h/drive, just in case...)
No problems so far with the following software:
Macaroni System Maintenance
Adobe CS3 Suite
Microsoft Office Suite 2008 Version 12.2.0 (much faster to open applications)
Capture One V4
Very impressed so far
Regards, Ian
Adobe CS3 Suite
Capture One V4
Regards, Ian
Posted on: 28 August 2009 by Lontano
It is quick starting up and closing down - excellent. Queues at the Apple store were not bad. They had lots of extra staff on duty taking your cash.
Keep getting some Microsoft Rosetta message that I need to research later.
I don't think Rosetta automatically installs with Snow, but if you need it after for some apps, like office i think, then i can be installed as and when.
anyone noticed i-tunes running quicker ? which was one of the promises.
On my MacBook Pro I ended up getting 16GB of space back on the hard drive. Just been reading some forums and others are experiencing similar if not bigger space saves. Wonder what disappeared during install! A few more machines to upgrade tonight so will see if a similar result achieved.
