Naimunit & Eyeconnect
Posted by: arasekhi on 22 March 2010
Hi,
I'm using Eyeconnect transcode Apple Lossless to Wav so it can be played on the Naimuniti. It works well, but I have quite an annoying issue that I'm hoping someone will have an answer to.
When looking at the Eyeconnect songs on the Naimuniti, the songs are ordered in what appears to be random order and not in the same order as they appear on the CD for example. Any ideas or suggestions on how to get the songs to appear (and play) in the right order?
Thanks in advance,
AR
Posted on: 23 March 2010 by 0rangutan
Within iTunes, create playlists for your albums and order the tracks how you would like them to play.
From the Uniti, browse EyeConnect and select your playlist - should work fine now.
John
Posted on: 23 March 2010 by vandergraafuk
I have noticed this as well. i have no solution either. think also you need to post in distributed.
Posted on: 24 March 2010 by Paul Stephenson
Eyeconnect sorts the songs exposed by it's UPnP server in the same order as they are sorted in iTunes. So, to sort by track name go to iTunes and click the 'name' column header. This will re-sort both the iTunes track order and the order exposed by the Eyeconnect UPnP server.
Posted on: 24 March 2010 by arasekhi
Thank you very much for your suggestions. I will try them.
