Sony KDS-R50XBR1 RPTV
Posted by: davidf on 23 January 2006
After doing alot of research, I believe this is the tv that I will go with. I compared it to many plasma sets and unless I want to spend big $ on a plasma ie $6000, this will be the best for me. I dont have to worry about plasma burn in or deterioration and this set is 1180P compatable. the picture is great. Only down side is it`s not mountable on a wall (not a big issue for me) and the off angel viewing is not as good as a plasma. Otherwise, it has the best picture on a 50" screen that I have seen. anybody else ever see this TV? david
Posted on: 23 January 2006 by Tuan
Yes...
It was my choice for the 50 inch TV but my bedroom is too small for it. I ended up with the SONY Bravia KDL-V40XBR1 LCD instead. You make the right choice. The one you select is a new Sony design LCD (high resolution) projection TV and the picture is beautiful.
Posted on: 23 January 2006 by Clay Bingham
This set is indeed spectacular and is on my short list as well. Just a note on 1080p compatibility. It has the resolution for 1080p but will not accept a direct 1080p input such as, for example, from a blue ray DVD. This is true of most 1080p capable sets at this time. I don't know if this is for coypright protection reasons or because of the lack of 1080p sources. Strange though.
Clay
Posted on: 23 January 2006 by davidf
Thanks guys, would you think that sitting 8 or 9 ft from the set would be appropriate? Also, what does 1080P compatable mean? If the broadcast eventually becomes 1080P, wouldn`t this set be able to take advantage of this? I am about ready to plunk down the money, but would like further opinions. david
Posted on: 24 January 2006 by Tuan
Just buy it and enjoy good movies with it. For the minimum viewing distance, it is recommended that you sit at a minimum distance equal to 2 x the diagonal measurement of your screen size.
Posted on: 24 January 2006 by David Dever
Word is, the iLINK (FireWire, IEEE1394, etc.) inputs will support full 1080p, albeit at a lower bit rate.
Oddly enough, the maximum resolution on the PC (VGA) input is 1280 x 1024, which excludes the possibility of using an external scaler (e.g., iScan HD+) for 1080p signals.
Again, do not forget to get the unit calibrated in-room by a trained technician. This can maximize projection video performance under the lighting conditions of your room, and is inexpensive relative to the performance benefits.
Posted on: 25 January 2006 by davidf
decision made: bought the sony. Will get it in a few weeks. Looking forward to using it! Thanks for the help, guys. david
Posted on: 25 January 2006 by Tuan
Congratulation. Now go and buy some good DVD (like LOTR) and enjoy.
Posted on: 25 January 2006 by Clay Bingham
Good for you. I'll be interested in your thoughts once you have it up and running.
Enjoy
Clay
