flatcap2/112/150
Posted by: hifi-dog on 11 February 2004
being new to naim stuff, do i need any additional leads to connect fc2 to 112/150 apart from the supplied 5pin din.
Ta
Posted on: 11 February 2004 by Pete Lewthwaite
In a word, no.
The 4-pin to 4-pin din lead that usually connects the 112 to the 150 is now used to connect the 150 to the Flatcap2 (the direction marker should be closed to the Flatcap2). The 5-pin din lead supplied with the Flatcap 2 goes from the 112 (you have to remove a blanking plug, but don't lose it as you may need it later) to the Flatcap2, with the cable direction ring closer to the 112.
If you want to use the 2nd pwer supply of the Flatcap2 (e.g. for a CD5 or Stageline), then you will require extra cables.
If you need any more info, there is a topic at the head of the forum which points you to the connections section of the main site.
Pete L.
Posted on: 11 February 2004 by ColinJ
No further leads are required. If I remember correctly, the lead supplied with the FC2 bridges the gap to the 112.
If you run a CD5, you will need to purchase an extra lead if you want power the CDP from the FC2.
