NAIT5 & FC2
Posted by: woody on 15 June 2003
Hi,
I have a (i.e. one!) FC2 which I am using on my CD5 and NAIT5. I know that on the CD5 it powers the o/p stage and on the NAIT it powers the preamp section, but I've not read much - if anything - on how best to use the FC2 in this kind of configuration. (lots on using it on CD5 only)...
What's the consensus of opinion? Should I use it on both nait and cdp, cdp only or nait only? would it be better to have a second one? (or try a s/h hicap - if it will plug in)
Thanks,
Andrew
Thanks,
Andrew
