UnitQute - FM Signal Strength
Posted by: Michael Chare on 24 November 2010
How do you display the FM Signal Strength with a UnitiQute?
Unlike the Uniti, it does not appear to have a signal strength option when you press the i button on the remote.
Posted on: 24 November 2010 by 0rangutan
Try the n-stream app? This gives the DAB strength and may do the same for FM. Will check later.
Posted on: 24 November 2010 by badlyread
No, nothing on n-stream. Just mono and frequency.
How strange - checked on my Qute and sure enough it is only DAB that provides a measure of signal strength.
Posted on: 25 November 2010 by okli
I never saw signal strength for FM on my Qute as well, but I'd much appreciate if I can see track number and total tracks displayed on the playback screen, using UPnP - there is a plenty of place for this info, but unfortunately it is missing or I'm too stupid to find out how to show it?
Posted on: 25 November 2010 by Michael Chare
You can configure DBpoweramp to prefix each track name with the track number. This keeps the tracks in the original order and also shows the track number.
quote:Originally posted by Michael Chare:quote:Originally posted by okli:
ok, this is workaround - I'd like to see this info on the top area where all other infos like volume, etc are shown - in case of UPnP source selection this line is almost empty, so why not using the space for something useful. Or may be another Info menu switching to this info.
