Strange problem with speaker balance -any ideas?
Posted by: max in hampshire on 17 March 2002
Hi
I have had my new system CDX 112 150 FC2 Allaes for a week now during which time it has been playing approx 12 hours a day which I would have thought would put it well on the way to being run in.
We have a two seater settee 9 feet from the speakers which are almost 9 feet apart. The room is 21 feet lengthways
My problem is that when I am sat in the centre of the settee ie centred between the speakers, the balance is correct. Moving a foot or so to the right makes no appreciable difference. But moving the same distance to the left moves the balance of the sound dramatically left. It becomes focussed very much on the left speaker.
All of which makes it difficult for me and my wife to listen together.
I have checked the balance is set properly.
I cannot see any logical explanation. Anyone out there have any ideas on this please.
Max
Posted on: 17 March 2002 by dvdkeogh
Is your room symetrical in plan (with speakers symetrically placed)?
I have little advice to give, but thought that ths ambiguity needed straightening...
Dave
Posted on: 17 March 2002 by max in hampshire
Dave
Yes totally symetrical - and speaker positions and alignment all carefully measured in centre of the long wall.
Max
Posted on: 17 March 2002 by garyi
I have the same problem, but as you can see I have little I can do about it, the left speaker sits on a side wobbly window!
basically when we moved in I took my space on the right hand side of the sofa and havn't moved since.
snigger.
Posted on: 17 March 2002 by Rico
Gary
what's that lower pane of glass next to the LH SBL? Is it an oversized catflap for a baby elephant, or what?
LG TV? IIRC they're pretty good. I think you should offer a prize for first punter to correctly guess TV programme captured in your screen shot. wink Just to clarify, I have no idea.
Rico - SM/Mullet Audio
Posted on: 17 March 2002 by Mike Sae
Max,
are both L & R walls made from the same material- is one a room divider and the other a load bearing wall for example?
I contend with this in my setup with adj to the balance control.
PS garyi is clearly enjoying his copy of Streisand's Yentil.
Mike
Thanks for that, it's an interesting question.
Actually both walls have windows but the window on the left is smaller than the one on the right. So, by definition, there must be more wall on the left. Something I hadn't thought of and could be a factor I suppose.
Max
Posted on: 18 March 2002 by max in hampshire
Bill
Thanks for that. I have read your other post. It seems that I have my electronics more or less in the position you have moved yours and interestingly we have similar size and configuration of our rooms.
You are the second person to make a reference to phasing so I will have to check that out. I thought my dealer had told me Naim could not be out of phase - something to do with the way the plugs are wired. Perhaps I misunderstood the point he was making.
I can certainly understand your comment that the sound appears to move every time you move just a few inches. I find it most distracting and it just isn't right.
To be honest whilst I do know what the balance control does I am not sure that I understand what a balance control is for. I have played with it but cannot see that it helps. It seems to me that if the sound is correct in one seating postion playing with the balance to adjust the sound for an alternative position will only disturb the sound at the original position.
I have played around with the speaker position but everything is set up exactly as it was at the end of a weeks home demo of the system prior to purchase. Today I am hoping a little more "running in" of the system will help, though I have been running it 12 hours a day for 8 days now. I certainly notice that each morning the sound shifts quite appreciably to the right after the kit has been playing for half an hour or so.
I will see what tomorrows tweaks bring.
Thanks for your input.
Max
Posted on: 18 March 2002 by garyi
The out of phase saga!
Ha I had the same belief when I decided to have a go at resoldering my cables.
Thing with naca5 is its quite simple to differentiate the two wires, it bascially likes to roll up neatly.
However sometimes things just work out that the + connector is actually going into the wrong hole.
Plug the speaker wire in to the amp, and follow the + connection to the speaker, is it right? Don't always trust the little tab on the plug, depends if the dealer knows his stuff.
If its not right, undo the screw remove the plastic outer shell, bend the plug points round and reapply the outer shell, hard to explain easy to understand in practise.
Either that or (if you discover you are out of phase) stick the offending channel upside down in the amp end.
Posted on: 18 March 2002 by Greg Beatty
In addition to the reflections issue mentioned above, the issue may be non-reflections.
When you move to the left the image shifts strongly to the left speaker suggesting that the right speaker is not being heard. Is there something on the right wall that would block a reflection of the right speaker when you move the listening position to the left?
Oh, and the balance control really isn't intended to fix the kind of problem you are having. The intend, I believe, is to center the image for one listening position in the case that the position is off center or the room is asymetric in some respect. It will widen or shrink the sweat spot.
- GregB
- Greg
Insert Witty Signature Line Here
Posted on: 18 March 2002 by Raphael
Hi Max
First of all congratulations on getting the Allaes - I am quite envious.
On your problem I have two suggestions. The first one requires spending some money - get a test CD - audiophilecandy.com have a good one for sale. This will let you test each speaker and then phasing etc. It will also allow you to do frequency sweeps etc. to check that each speaker is working correctly.
The second suggestion is to try and work out reflection solutions using old curtains/blankets or similar and some broom handles. Reflections can be a bit of a black art so use the broom handles to hold bits of cloth/material is different parts of the room to see if things improve or not. If you manage to find a 'hotspot' then hang something there!
I understand that your problem(s) have little to do with running in equipment but I would suggest that you need a good long while longer.
Good luck
Raphael
