My knob comes off when I twist it
Posted by: andrew mcmullins on 14 January 2003
Problem ...
On my 72 Pre-Amp the volume control was all loose. So I took the rubber cover and plastic cap off to tighten up the little screw. So far so good. Now when I put the plastic cover and rubber surround back on its all loose.
The rubber outer is different both ways around. Ie. there is a raised section in the middle and the width of the rubber is different on each side of the ridge. Looking at the other knobs it appears as if the plastic cap goes on the narrow side. Either way it is all loose and comes off. Being a muppet I decided to take the one on the source selector off to have a look. Thats okay but not perfect.
Do I need to use some adhesive? Am I doing it all wrong? Should I be taken out and shot?
Thanks, Andrew
Thanks, Andrew
