Audio Review Glossary
Posted by: Greg Beatty on 31 March 2003
I've been around this forum and hi-fi for years, but what in blazes do the following terms mean?
1) Darker - as in this speaker sounds darker than that speaker
2) Warm - as in the bass has warmth or the midrange is warm
3) Forward - as in the midrange is very forward
4) Laid-back - as in this speaker has a very laid-back presentation
5) Clinical - as in the speaker was very accurate but clinical sounding
These, and terms like these, appear in reviews and such all the time and the authors use them as if the meanings are common knowledge.
What other terms should I know about?
- GregB
Insert Witty Signature Line Here
Posted on: 31 March 2003 by Jez Quigley
...and 'dry'. WTF does that mean? Some use it (I think) to mean not much bass, but lord knows what others mean by it. Is it the case that no-one knows what these words mean but no-one (except Greg) dares to ask?
"All systems are perfectly designed to get the results they get."
Posted on: 31 March 2003 by bjorne
Prat- pace,rhytm and timing.
Jez, wtf? Wink
Posted on: 31 March 2003 by Jason Milner
FWIW, Stereophile publish a Hi-Fi Glossary at http://www.stereophile.com/showarchives.cgi?50
Mind you, whether you'll be any the wiser after reading it is another matter... Wink
J
For those that can't be *rsed to trawl the list, their versions of the terms you listed are...
dark
A warm, mellow, excessively rich quality in reproduced sound. The audible effect of a frequency response which is clockwise-tilted across the entire range, so that output diminishes with increasing frequency. Compare "light."
warm
The same as dark, but less tilted. A certain amount of warmth is a normal part of musical sound.
forward, forwardness
A quality of reproduction which seems to place sound sources closer than they were recorded. Usually the result of a humped midrange, plus a narrow horizontal dispersion pattern from the loudspeaker. See "Row-A sound." Compare "laid-back."
laid-back Recessed,
distant-sounding, having exaggerated depth, usually because of a dished midrange. See "Row-M sound." Compare "forward."
clinical
Sound that is pristinely clean but wholly uninvolving.
PRaT = Pace, Rhythm & Timing (my definition) - to which there are several references in this forum.
dry
1) Describing the texture of reproduced sound: very fine-grained, chalky. 2) Describing an acoustical space: deficient in reverberation or having a very short reverberation time. 3) Describing bass quality: lean, overdamped.
Posted on: 31 March 2003 by Greg Beatty
Thanx for the StereoPhool link.
That "cold" and "dark" mean nearly the opposite seems really strange to me.
I also thought "laid back" meant lacking dynamics. Wrong!!!
Oh well.
- GregB
Posted on: 31 March 2003 by gordon cavanaugh
tom,
synesthesia Cool
Posted on: 31 March 2003 by Martin Payne
Greg,
I would say Cold & Warm (and therefore Dark) are opposites (as in real life).
Cold, to me, would imply a thin and bright sound.
Me too. I suspect the one would tend to follow from the other.
cheers, Martin
E-mail:- MartinPayne at Dial.Pipex.com
Posted on: 31 March 2003 by Justin
These terms are best understood by listening to audio gear that exhibits them as well as gear that does not. I can imagine that people who do not have a lot of experience with differant makes of gear are more unfamiliar with this way these terms "sound" in real life. But, they DO have real meaning.
Take "dark" for example. An very old pair of Spendors (or Advents) will sound dark in comparison to newer pairs (or different makes). Upon hearing a pair of SA-1's from 1981, for instance, and then right after a pair of Kans from the mid 90's, the user will become intimately familiar with the term "dark" and its diametric opposite.
After repeated exposures to gear that make music corresponding to these terms, the user will become familiar with it.
In my case, I really didn't come to possess an appreciation for PRAT until I had an opportunity to listen to my Nait 2 against an integrated amplifier from ARC. Even the deaf would appreciate the difference.
Judd
Posted on: 01 April 2003 by Jez Quigley
Bjorne,
WTF = " What the f**k? "
It's an abbreviation I picked from playing online Quake too much. Sorry.
Posted on: 01 April 2003 by Jason Milner
Perhaps we should campaign for an update to the Unofficial FAQ, to include some of the more arcane Naimee terminology like "WAF" & "The Nagger" etc Wink
Posted on: 01 April 2003 by herm
I reject "The Nagger" as Naim terminology - it's just a unflattering habit of Mike's and one or two others, but no amount of Naim in my home could persuade me to speak of Rosie in these terms.
WAF is of course an entirely different matter.
Herman
Posted on: 01 April 2003 by Wolf
WAF had me stumped for a long time till I found it stood for Wife Acceptance Factor. Geesh, I thought it was something really important, but then for some of you it is.
glenn
Posted on: 02 April 2003 by Geoff P
All of the terminology is fine in these HiFi reviews but they seem to avoid terms like
The sound is "too expensive for mere mortals"
OR
"sounds like it bloody well ought to if you are listening to it attached to 20,000 Pounds worth of music generation appliances"
and so on....
GEOFFP
