Stands Unique 4-way mains adaptor.
Posted by: Mike Dudley on 12 April 2009
Does anybody use this? It looks like a good idea, but I am a bit wary, since it requires removing the plugs from all the NAIM-supplied mains leads, which NAIM state are optimal for their equipment, although this item has been recommended elsewhere in the forums...
Posted on: 12 April 2009 by Absolute
It seems from what i have read around here that the 4-way mains plug is an alternative to the grahams Hydra.
They both seem to be widely accepted and used, even recommended due to the 'star grounding' effect on Naim equipment. (Although i can clarify this)
A bit of searching should turn up plentiful results.
Posted on: 12 April 2009 by Bob McC
Used two equivalents of these for years and nothing's blown up yet.
Posted on: 15 April 2009 by schizo
I use one of these as I have stated before. In my opinion it is an improvement on a standard distribution block.
regards,
Schizo
