HDX updates
Posted by: g-h on 03 June 2009
Hi,
I'm about to purchase a HDX locally. My dealer and the distibuter in my country isn't very up to speed about what updates are available, or that there in fact are updates for the HDX.
Is there any way to get hold of these updates online, or am I stuck with the firmware I currently have?
Posted on: 03 June 2009 by Manu
Where are you leaving?
Posted on: 03 June 2009 by g-h
Am I leaving? Smile
I just need a firmware update, so I can get the most out of my purchase Winker
Posted on: 03 June 2009 by T38.45
g-h,
last time, the firmware update could be downloaded from naim web. put the code on cd-rw and install it ...no prob!
so you can start to buy your HDX ;-)
Posted on: 03 June 2009 by gary1 (US)
g-h,
Call Naim and ask them what firmware is no installed on the HDX. This will tell you if you need to do an update.
Either way, there will be a new software release supposedly in June which will need to be uploaded unless it is part of the newest HDX.
These updates need to be put on by CD obtained through your dealer from Naim.
If there is any issue I suggest you speak with technical support at Naim about your purchase and any updates to come. This is the easiest thing and will get you the direct answers you need.
