Controlling an AV2 with Sky+ remote
Posted by: HRC99 on 26 May 2006
Anyone know the code to do this?
I've tried the code listed on
here
but no joy. Anyone programmed one?
Posted on: 30 May 2006 by HRC99
42 views and no-one can help?
Posted on: 01 June 2006 by 110dB
I think that code is for Naim pre-amps
The pre-amp volume uses different remote codes (channel 16)to the AV2 volume control (channel 27)
http://www.naimusa.com/public/Technical_Documents/Naim_...emote_Codes_v0.3.pdf
Posted on: 02 June 2006 by HRC99
I've tried all the Philips codes listed too without success.
I believe the remote is made by "One for All" and I can't find a code on their website either.
