My SNAPs keeps shouting at me
Posted by: kid spatula on 05 February 2004
I got a dual rail modded snaps at the weekend (feeding a 42.5 + nap 90 into credos - all fed by a rega p25). It sounds great with some recordings(Neil Young, Stevie Wonder) ie everything is better defined and grooveier - but shouts at me with others (My Bloody Valentine, Aphex Twin, Squarepusher) ie the highs and mids make my ears hurt a bit... which never used to happen.
Do I need to play the "let's shift the speakers around" game?
Or am I just hearing, for the first time, that MBV, AFX and SQPR all produce *really* harsh sounding music?
Posted on: 05 February 2004 by NB
give it time to settle down and see if it's the same in a month or so. If it is and you don't like it , then look at tweeking the set-up to get more out of it.
NB
Posted on: 05 February 2004 by kid spatula
A month?!
Wasn't there a thread about it only taking a couple of hours for naim stuff to warm up?
I will give it another 3 days - that will have been a week. If it's still troublesome after that I'll try shoving bits of toast into it and cutting up old wellies for use as supports.
Or try mana....
Wink
Or send it off to avonda
