Spotify Problems
Posted by: floid on 02 November 2009
Hi all
Just listening to Spotify and am having problems with it stopping and starting. Does anybody else have this problem. Is it better if you pay for it.
Posted on: 02 November 2009 by Bluetorric
Right click on the icon in taskbar at the bottom of the screen if using windows then left click on exit and it will stop, hope that helps............
Posted on: 02 November 2009 by floid
I'm trying to listen to it not shut it down
Posted on: 02 November 2009 by Sir Crispin Cupcake
I've been having this problem too. I suspect in my case it is crap broadband speeds which seem to have got worse recently. I do pay for Spotify and as this gives higher resolution streaming, if anything paying for it may be making things worse.
Rich
Posted on: 03 November 2009 by Bluetorric
You did say you had trouble starting and STOPPING it...........
Posted on: 03 November 2009 by floid
Rich
Thank you for that I think I will leave Spotify until I upgrade my broadband I find it at times hard to listen with it stopping and starting every 30 seconds or so.
You sir are an idiot
And you sir are a moron,
If you won't take advise, don't ask for it
I was only trying to help, I will not waste my time in the future.........
