Has anyone ever used a Stageline with the NAC52? I have a Stageline with K boards and have been thinking of trying it with my kit. I was wondering if anyone else has tried it or has an opinion.
Tony
Posted on: 12 June 2002 by Martin Payne
Tony,
I use a 'K' Stage, powered off input 2 of my 52.
I was not expecting an improvement over the internal boards, but I think it was better. I mainly bought it to enable me to distance the LP12 from the Naim stuff.
I have also tried running it from a HiCap and it was a big upgrade again. One day!
If you do change over permanently to the Stageline, remove the internal coil boards from inside the 52.
cheers, Martin
Posted on: 12 June 2002 by smiglass
Thanks, Martin. This was the information I was looking for. I have K boards on the 52 but wanted to see if there could be an improvement with the stage. I will try your suggestions and post later.
Tony
