Problem with CD3.5/NAC82 - earthing?
Posted by: Jeremy Roebuck on 24 August 2003
NAC82 system works fine till you plug a 3.5 CD player in - soon as the interconnect is in place the 82 dies - none of the other sources is earthed and suspect it may be something to do with the Naim CD earthing the pre-amp - perhaps due to something anomolous in the set up of twin Hi-Capped 82
Any help or advice much appreciated
Jeremy & Paul - frustrated in Leicestershire
Posted on: 24 August 2003 by andy c
Hi,
Just to assist anyone who can answer Jeremy's question above, the 3.5 used to live with a NAC102(Flat-capped & NAPSC)into a NAP180. The 3.5 has been recently used as a standalone/flat-capped/hi-capped, and has also been used with a non-Naim interconnect as well as the Naim supplied one.
We were using it through this system this morning with no problems experienced...
regards,
andy c!
Posted on: 24 August 2003 by Jeremy Roebuck
It played fine on Andy's system this am - really nice. Connecting to Paul's 82 this afternoon whatever order we turned things on. as soon as the 3.5 was live & connected by 5 pin DIN to the 82 all the lights on the 82 go out
Paul's system is more complicated than mine with twin Hi-Caps so I'm hoping it will be OK on my 102 but any clues would be much appreciated
JeremyPS thanks for your help & concern Andy
Posted on: 24 August 2003 by Mick P
Did you notice Patricks last statement about the shorting plug.
In the previous set up, a flatcap was used, therefore no shorting plug was used.
You will need it in your system and if you don't have it, there will be no sound.
It is a plug which fits in the back of the CD3.5.
Mick
Thanx for input but no, shorting plug is in
Jeremy
This is almost a case of sticking an interconnect into the wrong socket.
I suggest that you give Naim a ring and they will send you a small booklet which shows what goes where. I find it indespensible.
Mick
Posted on: 25 August 2003 by prowla
You can download Naim manuals in PDF format.
I found some at flashback.
Paul Rowlands
Posted on: 26 August 2003 by andy c
Jeremy,
check your private topiks,
regards,
andy c!
Posted on: 26 August 2003 by Jeremy Roebuck
Problem now solved - plays fine on my system - looks like Paul has a problem with the star earthing on his 82 which he is going to speak to Naim about. Thanks to all, particularly Andy
Got to go & listen to some CDs
Jeremy
