NaimUniti and n-Link iPod Connector
Posted by: chris_p on 08 December 2009
Is anybody else having trouble with this £95 cable?
I have to restart the Uniti or disconnect and reconnect the n-Link every time the unit is paused/stopped and left for a while.
When I attempt to listen to the iPod again a 'Please Wait' Input Initialising message appears and the Uniti freezes.
other inputs are fine. They select and play normally.
Once playing it all works well but I would not have bought the n-Link if I had known of this 'feature'.
Posted on: 09 December 2009 by AV@naim
Which model/generation Ipod?
Posted on: 10 December 2009 by vandergraafuk
Hi,
I had a similar issue and it turned out to be the connection at the rear of the Uniti. Because the cable is a bit stiff it would work its way loose. I supported it with an old small glass tumbler and a bit of blu-tak. Hope this is a bit useful to you.
Posted on: 17 December 2009 by chris_p
Sorry for the delay.
iPod Classic 160. Latest firmware and software.
