Dura-Ace ten speed
Posted by: Tim Jones on 16 September 2003
My dealer has the first ten speed Dura-Ace guppos in the UK (or so he says) Anyone tried it yet? Any views?
I'm thinking of getting it put on the C40.
Tim
Tim
Posted on: 16 September 2003 by Former member
Some shops had the new 10s for testing last weekend (13/14 sept), but I didn't have any opportunity to try it. I will try it next sunday at Milan cycling exhibition and will report.
However, I saw it in the flesh in may, and was impressed about some innovations.
Most professionals who are using it have reported enthusiastic comments, especially for the shifting mechanism.
Some people say that the new crankset/bottom bracket may have some trouble (too stiff?) but it's only rumors.
BTW I was in Paris for the arrival of the Tour and had the oppurtunity to observe some professionals' bikes equipped with the new Dura Ace groupset. Only a few had the new crankset/bottom bracket. Most had preferred the old one.
As far as the look is concerned, I prefer the old one.
Stefano.
Stefano.
Posted on: 16 September 2003 by John Sheridan
infidel!
Posted on: 16 September 2003 by ErikL
International Disaster
Chaps
Japanese parts should never be used on European frames. It's just wrong.
Ludwig (sarcastically doing my Mick Parry impression
Chaps
Posted on: 16 September 2003 by Dan M
Tim,
Surely it's time to upgrade - the new C50 can be had with 10 speed Campy. A snip at around $6K.
cheers
Dan
cheers
Dan
BTW Campagnolo is now offering a new 2004 Record, although most innovation is just cosmetic.
If the upgrade bug has hit you once again you might start thinking at the 2005 electronic Record...
...forgive me, for I have sinned:
My time trial bike is equipped with a Shimano Ultegra. And even worse, I like how it works.
Stefano
infidel!
Stefano
Posted on: 17 September 2003 by John Sheridan
Hopefully you might be able to help me here Stefano. What advantages does electronic shifting offer? I can't see any benefit in it. In fact, it just seems like a disaster waiting to happen. Is there some inherent problem with cable shifting that I'm not aware of?
oh, the shame of it all.
Posted on: 17 September 2003 by Former member
Speaking of Campy, does anyone have the Campy carbon seat post? I was thinking of getting one, but there seem to be lots of reports of breakages, and the seat post is not the place to have a sharp, upturned piece of carbon fibre (ouch!). I've ordered the Campy titanium seatpost instead. Any experiences with this?
Stefano, how does Ultegra compare with Record for ease and smoothness of shifting? I'm quite impressed with the Ultegra groupset on my Trek, but already thinking of using Record with the De Rosa King* I plan to buy next (since I've now had the Trek for all of three weeks!).
Ross
* Saw the De Rosa in a bike shop on the weekend, as well as the C40. The C40 was great, but with the De Rosa it was lust at first sight.
Ross
Posted on: 17 September 2003 by Tim Jones
Dan -
Actually you're right - I may save up for a new frame to put the DA ten speed on - maybe a C50, but the carbon Cervelo looks good too and might, just possibly, be a bit cheaper...
It's only three months since I bought the C40. Oh well.
John/Ludwig -
I don't buy this stuff about not putting Shimmy on Italian frames. Most of the pro teams who rode/ride C40s put Dura Ace on them. FWIW I like both DA and Record - and think they stack up a bit like this:
Shimmy DA - Upside: Bit cheaper than Record (at least the 9-speed was), slightly easier to set up, slightly more robust, better shifting while on the drops.
Downside: Always seems a bit noisier than Campy stuff, you can only shift one cog at a time, no funky carbon fibre, very slightly heavier than Record, spongey brakes
Campy Record - Upside: Looks nicer, more purist, multiple shifts possible (actually I do miss that), more 'definite' shifts, better brakes.
Downside: Expensive, reputedly more fragile, carbon fibre parts no substitute for genuine technical improvement, shifting up while in the drops is a nightmare unless you have double-jointed thumbs.
It's just that for me, Shimano wins out by a whisker - plus all my other bikes and wheelsets are Shimmy, so moving to Campy would be a tad inconvenient...
Tim
John/Ludwig -
Tim
Frankly speaking, I have no idea. At the moment it's only rumors, nothing has been officially confirmed from Campagnolo. I believe it's mainly a marketing move, similarly to what happens in the hifi market (companies MUST invent something different, not necessarily better). It will cost a fortune, probably.
There's nothing wrong with cable shifting! Actually ALL modern groupsets work very well and there's little room for improvement.
I had one, now I have the carbon Colnago one which is supplied with the bike and looks very similar to the campy one. I have always considered it as one of the safest places to hold a seat, I have never heard of a broken one. Certainly it's overpriced, but if you buy the whole groupset it's included in the price... so why not? Because of the technology cascade, the titan setpost is now part of the Chorus groupset I believe. I also had one on my old titanium Bianchi. Worked well until I tried to lift the seat and discovered it was glued to the frame and could not move it!
Since it's a TT bike I don't have the integrated brake/shifters levers, I have separate brakes and small shifter on the aero bar. However, shifting is extremely smooth, certainly not worse than the Record. Given the wide price gap, the Ultegra is definitely the way to go for nearly top bikes. You can buy a Record for 1.250 Euro while an Ultegra sells for 590 Euro down here (pedals not included), while the Chorus (Ultegra's competitor) is 950 Euro (street prices, much lower than official ones).
Stefano
OK please tell me you're both joking... Your bikes are not even run in and should last several years!
A brand new bike won't let you ride faster (Tim) or won't help your feet get out from clipless pedals (Ross)
My 2001 C40/Record is now entering its 3rd racing season (nearly 40.000 km in the sun, rain, dirt, wind - and snow one day) and there's absolutely nothing wrong with it. I have only replaced the chain (at 4.000 km interval), the rear rim and the crankset since I moved from 170 to 172.5 mm. Plus the right brake/shifter carbon lever was replaced by Campagnolo for free.
So please stop thinking about upgrading your bike, but train hard and ride faster and faster and faster...
Stefano
Stefano -
I, uh, do realise that a new bike won't make me a faster rider. I train hard no matter what bike I have and am currently training on my 'heavy' (i.e. 8.5kg) Deda7003/Ultegra bike and racing (increasingly successfully) on the C40. If I do get a C50 or the Cervelo it won't be until early next year. Anyhow I'm going to sell the Principia
Buying a new bike is like upgrading your hi-fi. It won't improve your taste in music, but will make you want to explore music more.
Tim
Tim
plus:
So it makes six months... which is a very long time compared to:
...the De Rosa King* I plan to buy next (since I've now had the Trek for all of three weeks!).
However as you well know I'm only kidding.
Obviously I have nothing against people upgrading/downgrading/sidegrading their bike frequently, and must admit that I'm continuosly tempted about buying an aluminium bike (NOT to replace the C40 BTW). Not to mention wheels...
Stefano.
Stefano -
I think you're just jealous...
If you're looking for an aluminium bike, I suggest you find someone who has a second-hand Principia for sale.
Tim
Tim
quote:Only half joking, Stefano. My current Trek is a great bike, and modestly priced compared to the Colnagos, Pinarellos and De Rosas, and it is probably ideal for a novice like me. However, within a year or so I expect to want something lighter and more comfortable, which means carbon fibre, and if you're going to spend that much on a bike, you might as well buy one that is a work of art like the Colnago or De Rosa. Also, I get the feeling that riding a Trek is like driving a Toyota - competent but commonplace and dull - while riding a De Rosa or Colnago is like driving a Maserati. I don't actually want a Maserati, but I do want a De Rosa (which is funny, because a month ago I'd never heard of either De Rosa or Colnago).
quote:I plan to train pretty hard on it for at least a year before buying a new bike. I'm already doing about 200km a week, and expect to increase that substantially as the strength improves and I find some long group rides. But asking someone to stop thinking about upgrading - now you are being completely unreasonable.
quote:What would you buy, and for what purpose? Are you looking for something lighter and stiffer for shorter races?
Incidentally, how can anyone not want one of these ...
Ross
Oooh I dunno Ross - they are not especially light and had a terrible review from a Mr Chris Boardman in Procycling recently. he seemed to feel they their geometry makes them handle like a welder's bench.
Also they're very expensive and have a bit of a poseur reputation (nothing like a C40 obviously
If I was going to buy a De Rosa it would either be a Dual (the U2/carbon one) or a Merak (the V107 one which has a great pro pedigree).
Tim
Tim
Posted on: 17 September 2003 by ErikL
Tim, I was joking about a Japanese groupo on an Italian frame. Why would I care what anyone puts on their bike?
Re: electronic shifting, a friend once had a Serotta Ti frame w/ Mavic Zap 6-volt setup and while very interesting it didn't work as well as a mechanical system.
Come on Tim, it's not the Principia I'm interested in but you know I might be after your brand new C40
True. You really don't have a clue about how many times I've been reading the 'road bikes guide' looking for the frame and accessories that would suit me best... The point is I always end up with a C40/Record!
I would certainly buy a custom made Airplane (by Columbus) or the Dedacciai equivalent. I don't mind the make, in this case. I'm not an ultra light frame freak, but I'm looking for a stiff bike with a very quick response. That would be ideal for short races, but I do plan to use it for long races as well.
In fact I'm lucky enough I don't feel any kind of pain at my back even after hours and hours, plus I generally use low profile tubular wheels for racing, which really help as far as comfort is concerned.
The King is wonderful, as is the Carrera Pitbull which has a very similar design. Actually a couple of friends have swapped their C40 for one of these and swear the Carrera is better.
Ludwig
the Mavic Mechtronic was a complete failure and the Campy will certainly have nothing in common with it.
Stefano.
Colnago site updated!
Colnago has unveiled some new stuff for 2004 and I'm really impressed. Have a close look before you plan your next upgrade move.
My C40 is obsolete today
Posted on: 18 September 2003 by Tim Jones
Oh my God. I've got to have one. It does look a bit like the new Trek frame though. I think it's going to have to be a C50 in PR4...
Anyone wanna buy a CDS2/52/135/SBL system?
It's about time Colnago updated their site. I've never heard of some of those frames ('Active'? 'Mix'? 'Rapid'?). Nice to see that they're updating from CT1 to CT2 as well, but it looks like more of the frames are sloping, so perhaps Sgr. Ernesto is compromising his principles...
Tim
Tim
Posted on: 18 September 2003 by Former member
Tim, just out of curiosity, why would you prefer the C40 or C50 to the CT1 or 2 - i.e. why is CF inherently preferable to titanium?
Ross
Ross
Posted on: 19 September 2003 by Tim Jones
Ross -
Oh dear. This could turn nasty. Many people love Ti bikes and they do feel great in many ways. I did not test a CT1, but did test ride a Litespeed Ghisallo before deciding on the C40. It was extremely light and very comfortable to ride.
The C40 had all those things, but was also (much) faster accelerating, stiffer, more stable and comfortable at high speed, and less twitchy on fast descents. There is also something hard to define about what a C40 does when you really stand up and go all out. It just seems to let you go harder than any other frame I've ridden.
How far this experience translates to other carbon or Ti frames I'm not sure. I've ridden a Trek 5900 but thought it was a bit dull. I suspect many of the C40 attributes are due not only to the carbon fibre, but to the fact that it's built into a frame with a very steep seat tube angle, a shallower fork rake and ten years of feedback from the best pro riders in the world.
Tim
Tim
Posted on: 21 September 2003 by rafizi
tim...hi there
it's me again, rafizi.
well, to me, italian frame goes with italian gruppo.
regards,
regards,
Posted on: 21 September 2003 by Former member
Back to the topic...
I have visited Milan cycles exhibition yesterday and could finally test the new Dura Ace 10s. I had been told it was exceptionally smooth and silent but I was gobsmacked! It's really close to perfection, something you wouldn't expect.
The levers are longer and the effort required for braking and shifting is really minimal. The grip is much better than the old version and can suit both large and small hands. The shifting mechanism for both front and rear derailleur has nothing to do with ANY other groupset. You can hardly hear a 'click' and it's as fast as you can't imagine. The crankset is said to be extremely stiff (Shimano say stiffer than carbon ones) but riding on a turbo training wasn't enough to test it.
As far as the look is concerned... well I was wrong. I had seen it in a showcase in may and wasn't impressed. But when assembled on a bike it's spectacular.
As all the groupset components, hubs are completely redesigned yet compatible with old 9s hubs so that you can use your old wheelset (or put the new wheelset on your old bike).
BTW the new wheelset is terrific too, but perhaps too expensive (They say approx 1200 Euro).
The price for the whole groupset shouldn't be too far from the 9s, so this makes the 10s a tremendous bargain.
As a hardcore Campagnolo feticist I can only hope for a quick and effective reply from the Italian company which goes far beyond the 2004 Record version.
Stefano.
Stefano.
Posted on: 22 September 2003 by Tim Jones
Stefano -
Thanks for that. It sounds really good. I have to admit that I wasn't sure about the look of it, but it seems more impressive when you actually use it.
The bit that I did really like the look of was the new Dura Ace wheelset - it looks like Campy's excellent Neutron/Nucleon wheels. Do you know how much it weighs?
Tim
Tim
Posted on: 22 September 2003 by Former member
Tim
Of course I do, I have a brochure:
WH-7800 wheels, for clincher only. Rim height 24 mm, rim width 20.8mm. 16 spokes front, 20 rear. Weight 721g front, 852g rear.
I'll never regret enough for selling my Nucleon clincher wheelset. I swapped them for a Ksyrium tubular set and although I'm very happy with my current set, I must confess I really prefer the Nucleons to Ksyrium (the Nucleon tubular set, that I've never tried, must be something special).
Stefano.
Stefano.
