No 5.1 from $ky HD box
Posted by: Blueknowz on 03 January 2008
No 5.1 from HD box??
Last night for no apparent reason I lost 5.1 sound from my HD box ,the sound is fed via an optical lead to an amp ,which on all other channels is o.k. apart from Sky Movie channels & of course any HD channel, calling $ky was a joke,they took me through all the usual routine of disconnecting form the mains & HDMI cable ,they kept insisting I was getting no 5.1 becuase of a faulty HDMI cable ,but I have tried the component cable with the same result ,anyone else had this problem ,of corouse the box is now out of warranty ,anyone any ideas ???........Jim
Posted on: 04 January 2008 by nap-ster
Have you checked the audio settings in the Sky box haven't been changed?
Posted on: 04 January 2008 by Blueknowz
Audio settings still reading Dolby D ,someone on Digital Spy suggested the settings sound as though they have been changed to PCM somehow ??.....Jim
Posted on: 04 January 2008 by tonym
Just to clarify - you're using the digital optical connection into a surround sound processor/amp and the DD 5.1 is working OK except on Sky movies and HD? Bearing in mind not all programmes on these latter channels are encoded with DD, are you sure it's actually being transmitted?
Changing from HDMI to Component won't affect this problem. Can you try another optical digital input?
If it's definitely not the processor at fault, insist on a new Sky HD box, even if it's outside of the warranty. Threatening to cancel your subscription usually works wonders!
Tonym ,I,m getting 5.1 from all other sources i.e.DVD,Xbox,so it,s not the amp I,m getting no sound at all from Sky Movies or the HD channels ......Jim
Posted on: 06 January 2008 by Blueknowz
Box replaced after checking set up I was able to show him how I was getting all channels be it only in Pro Logic ,but not in 5.1 he agreed the 5.1 decoder had gone in the box ,so I,m happy for now!.......Thanks for your help guys ....Jim
