Direct to CD?
Posted by: Chayro on 09 April 2006
Reference Recordings has put out two "Direct to CD" recordings of Dick Hyman on the Bosendorfer Reproducing Piano, which records the artist as they play and then plays it back "perfectly" according to the artists themselves.
In any case, these two CDs, one of Ellington and one Fats Waller, are cut directly to the glass master as the Bosendorfer is playing, and is not cut from some previously-stored digital source. According to RR, these are supposed to have an unprecidented purity, as a generation of digital transfer is eliminated. The cost is approximately $30 USD, as opposed to the same release done Reference's conventional way, which costs about $15 USD
Dick is a great player and the music is really worthwhile, so, sonics aside, there is a lot of meat here, if you go for solo piano of course. Sonically, I have not compared them to the conventional versions, but, as with all Reference Recordings, the quality is superb.
Just mentioning this for those of you who may be interested in such things. BTW, I believe you may be able to purchase the Fats Waller recording on Vinyl if you look around. Cheers.
