Sky HD code for AV2
Posted by: Don S on 04 February 2010
Is there a code to control the AV2 with a Sky HD or Sky+ controller?
I have searched this forum and Googled the internet. Threads exist but no working codes are forthcoming. Is it therefore definitive that this can't be done.
Posted on: 04 February 2010 by tonym
Hello Don & welcome to the forum!
Unfortunately I suspect it's unlikely you'll be able to use your Sky controller with your AV2. You might be better off getting your hands on a universal "Learning" remote to control the AV2 and the Sky-box.
Posted on: 04 February 2010 by Roy Donaldson
The Sky remote has the URC database in it, so you should be able to set this up. Look at some of the Satellite forums on Digital Spy perhaps.
Roy.
Posted on: 05 February 2010 by TomK
Reference to Sky + and Naim here.
Posted on: 17 February 2010 by Don S
Thank you all for your input. I checked Tom's suggested website and have already looked at satellite forums both without success. I therefore conclude that Tony is right and that the Sky remote cannot be programmed to change the volume on an AV2. I would have expected Naim to have firmware options to avoid potential conflicts but it looks like they have come up with their own propriety codes that are not on Sky's URC database.
