Nait 5 malfunction
Posted by: Justin on 22 August 2003
For those who have a Nait 5, when the volume is turned down, do you still hear a buzz through the speakers? My Nait 5 makes a buzz noise, which I apprehend to be a bit more pronounced than is ussual with Naim.
When I use the nait 5 as a pre-amp only (with a 150) the buzz goes away. But if I have the amplifier of the Nait 5 in circuit, it comes back. What gives?
Judd
ps. the flexibility of the Nait 5 is really quite nice. I particularly like the fact that when used as a pre-amp only, it takes NO power from its own PSU. THAT's attention to detail.
Posted on: 24 August 2003 by cam
Hi Justine,
I've the same problem and asked my dealer. It's got to do with the 'unclean' electrial supply.
I was advised to do as NAIMGAIM suggested. However, I'm resticted due to the room's layout - guess I'll just have to live with it. Frown
