Gapless play?
Posted by: docmark on 01 August 2010
I've noticed that for some music, the HDX 'chops' the end of the tune, and then onto the next selection. For example, on the Cars Candy-O, several of the tracks run into each other, but when I play them back, there's a gap. Another example - Steve Miller - the Space Intro should run right into Fly Like An Eagle. Is there a way of ripping CDs so that on playback, I'll hear this continuity?
Posted on: 01 August 2010 by Phil Harris
If a disc is properly authored then there should be nothing chopped from anything and tracks that merge together should still merge together correctly ... it's possible that there may be a quirk in the authoring of the disc so if you drop me an email at my work email address (phil.harris@naimnet.com) then if it's OK we'd appreciate borrowing one of those discs to take a look at.
Phil
