Jean michel jarre
Posted by: liam on 14 May 2006
Hi all,
just wondering if any of you have any newer versions of oygene or equinoxe on cd.
the reson i ask is that i already own them in a box set from the late 80's on cd, but would like to hear rematered versions.
can anyone recommend which versions to get?
cheers
liam
Posted on: 16 May 2006 by naimlover
Hi Liam,
As the owner of an original Oxygene LP from 1978, I can only say that I have been very favourably impressed by the more recent 24/96 remasterings on Sony/Epic. I feel that the full value of the LP has been retained in these CDs, and they are definitely worth getting.
I have Oxygene and Equinoxe in remastered versions, each picked up for less than a tenner in the HMV sale, so look around and compare prices. Catalogue numbers 01-487375-10 Oxygene, 01-487376-10 Equinoxe. They both say 'Digitally remastered 96khz-24bit technology by Masterdisk New York' on the back so they are easy to tell.
Hope this helps
Posted on: 16 May 2006 by J.N.
I recently purchased a 96Khz - 24 bit remastered CD of 'Oxygene' on the French Dreyfus label FDM-36140-2 (remastered by Scott Hull, Masterdisk, New York) which has a superb sound quality.
There is reference in the French sleeve notes, to efforts being made in the remastering process, to retain the warmth of the original analogue recording.
It's a superb job - a nice balance of clarity and smoothness. I can heartily recommend this version, and I reckon it's a modern and timeless classic.
John.
Posted on: 17 May 2006 by Bob McC
I once went on a coach ride inland in Morocco for 24 hours and the only music on board was 'Oxygene' looped.
They can't do be doing much more cruel at Guantanamo IMHO.
Posted on: 18 May 2006 by thejejk
You mean they didn't play the remastered version? Winker
Posted on: 21 May 2006 by naimlover
Unfortunately, good though 'Jarre in China' is in theory, it is dire in practise. The music appears to have been recorded off a PA feed, there is no ambience or sense of occasion, which is shocking considering the amazing venue; my suspicion is that he is miming to preprogrammed tracks.
Try before you buy on this one.
