n-Vi analog audio output issue
Posted by: JohnS on 03 July 2006
Before my n-Vi committed seppuku, I tried to connect a pre-amp to the analog audio output 180ยบ five pin DIN connector but I couldn't get any sound from it.
Is there some option, concealed deep within the menu structure, to enable it? Does it have a weird pin connection? Has anyone else had similar issues?
Posted on: 03 July 2006 by David Dever
For best results, set the front speakers to Large - External.
Posted on: 04 July 2006 by Tuan
Only Sony [Japanese] can do this not Naim [laughs]
Posted on: 04 July 2006 by AV@naim
Make sure you are using the output socket and not the input (I am sure you are though)
Straight 5:5 needs to be used
Set as Dave D's post (Hi Dave)
