Capacitor's" Sourcing"
Posted by: raymond on 02 December 2002
Hello to all, my power amp needs re-capping, I require the following value, 17,000uf, 80volt or as near as possible. I have tried to source them from Maplin and Farnell without success. The manufacturer of the amp has long since gone. The power amp is 25 years old so a recap is way overdue. Anyone know of an off the shelf supplier?
Raymond.
Raymond.
Posted on: 02 December 2002 by Paul Ranson
The exact capacity isn't too important, apart from anything else there's a huge tolerance on electrolytic caps.
The big questions are voltage, ripple current and size. 80v seems very high for an audio amp
I would be surprised if RS didn't have something suitable, 381-9122 for example. http://rswww.com/
Paul
Paul
Posted on: 02 December 2002 by raymond
quote:Thanks Paul, ill check RS out. Yes 80v seems high but it's an american power amp delivering 600watts r.m.s.into 2ohm and around 400 into 4ohms, the laminated transformer is massive and the amp never gets warm even driving Isobariks.
Paul
Raymond.
[This message was edited by raymond on MONDAY 02 December 2002 at 14:57.]
Posted on: 02 December 2002 by JohanR
What can it be? From your text one guesses that it's a brand that has gone out of business.
- GAS?
- Phase Linear?
- or?
JohanR (amateur HiFi historian)
- GAS?
- Phase Linear?
- or?
It will have power rails in excess of 56v, so a 63v cap is definitely marginal.
Paul
Paul
quote:Hello JohanR, the power amp is a Dunlap-Clarke, Dreadnaught 500 and yes it's american, imported by Exposure Electronics before they made there own amplification products. Circa 78. Have you heard of one?
- GAS?
- Phase Linear?
- or?
Ray.
Raymond.
[This message was edited by raymond on MONDAY 02 December 2002 at 14:57.][/QUOTE]
Hello Paul, I have located the caps on RS, 100v, 22,000uf but are fairly expensive at £31.50 each.
Ray.
Paul
Raymond.
Ray.
