Manual clarification please .. Naim UnitiQute, Settings/ Speakers/ Type
Posted by: PhilW on 03 December 2010
There are three choices here: small, large, or "none".
Here's what the manual says:
I don't have an external power amp or a sub woofer, so I don't want "large" it seems. But then reading the text for "small" I don't want that either.
"None" is easy: it makes no noise.
Ok, I should be able to just try it and listen, but I've a pile of variables to play with and I'd like to have this set right to start with. "large" seems to work, although if my girlfriend asks, they're definitely "small".
Does anyone have any idea what this setting is for and what it should be set to?
quote:"Select the Large option when the UnitiQute preamplifier
output is connected to an external power amplifier or to a subwoofer used to augment the low frequency performance of large (full bandwidth) speakers.
Select Small only when the UnitiQute preamplifier output is connected to a subwoofer used to provide the low UnitiQute Setup frequency component of a speaker system incorporating small (restricted bandwidth) satellite speakers. When
Small is specified, a 100Hz high-pass filter is applied to the
UnitiQute speaker output signal."
