I want to update my Graphics Card But!!
Posted by: Blueknowz on 17 June 2008
I have a Asus M2N-SLI Deluxe M/B ,Ge Force 6200 Turbo Cache(TM) & a 2232 BW Samsung Syncmaster monitor ,I want to change the GC to a Ge Force 8800GTS 512mb,But this card has dual DVI outputs ,The problem is I don't get a signal when using the DVI connection any ideas ?.....Jim
Posted on: 17 June 2008 by Whizzkid
Blue,
Did you not get a DVI to VGA adapter with the card so you can use the VGA input on your monitor?
Dean..
Posted on: 17 June 2008 by Blueknowz
Dean ,I have it sorted now some one on PF suggested this in display properties, you will see a picture of 2 monitors 1 & 2 (2 is usually greyed out) you can hit the identify button to make sure what screen you are seeing you can use the drop down menu or just click on the picture of monitor 1 or 2, select 2. you will probably have to select 'extend my desktop onto this monitor' (tick box) before the 'Use this device as primary monitor' is 'enabled' - select that. after apply/ok you can hit your input selection button on your samsung to see if DVI will pick anything up
Posted on: 18 June 2008 by Whizzkid
Ah! I see you use Windows so that bold text went over my head, but I'm glad its sorted Blue.
Dean..
