Fixes, upgrades and similar
Posted by: David Stewart on 16 September 2003
I posted this message to the Mods in the PIC upgrade thread but it didn't attract a response there, so I thought I'd try again, just in case any of them are awake.
Why not set up a separate room (read only) where you guys can post details of available upgrades and problem fixes, like the CDP PIC upgrade. That way everybody will know about them and will have a place to look if they run into problems.
Another 'fix' that springs to mind is the puck nipple tweaking fix to stop CDs slipping. The problem commonly crops up in here so why not list the fix prominently.
Similar things like system setup recommendations might also be included and any other hints and tips which you knowledgeable mods have to hand.
So what do you think??
Posted on: 17 September 2003 by Richard Dane
Hi David,
this is under consideration. Most issues concerning CD puck maintenance are covered by the Unofficial Naim FAQ which has a link at the top of the page (or click here: http://comedylimp.com/naimfaq/ )
The only issue which isn't covered in the UNFAQ is the copy-protection PIC upgrade. The thread relating to this is now pinned to the top of the Hifi Corner page.
Richard
Posted on: 17 September 2003 by David Stewart
Richard,
Not everyone is aware of the unofficial FAQ, so newbies probably wouldn't think to look there.
A FAQ room would also give you an opportunity to make people more aware of what service upgrades are available for older products. Things like re-casing old siver bumper amps etc. I for one have no idea of what is possible.
I also noticed recently in another thread, something about a dealer fix for overly bright front panel lights. This sort of thing could all form part of a knowledgebase users could search.
This would enhance the Naim Ownership Experience, which I'm sure is something close to your heart. Smile
Posted on: 17 September 2003 by Tuan
Originally posted by Richard Dane:
Hi David,
Richard
This site needs to be updated. Naim Audio should take positive action to keep the information up-to-date. I see no mention on the new series, the information there should be reviewed/added by Naim Audio.
