NaimNet servers and NAS drives
Posted by: jcs_smith on 02 February 2008
Will an NS01 be able to work with a networked NAS drive instead of or as well as a PC as a file server? If so is there anything you need to load on the NAS drive? I have Squeezecenter and Twonky running on mine but they were pre-installed. I've heard it can be quite complicated getting other media products to install
Posted on: 02 February 2008 by David Dever
Yes, the NS-series servers will be able to access NAS storage. You can also connect some NAS boxes via USB to the rear of the unit, as direct-attached storage.
Posted on: 02 February 2008 by SteveH
Just to add to David's reply; you won't need to load anything to the drive.
